Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-08-2008, 05:40 PM
matt71 is starting off with a positive reputation.
Oil Leak
Well guysI think I may have tracked down my oil leak in the valley of my 7.3 It looks to be leaking from the HPOP. Is there a gasket or something that could be bad? Is removing the HPOP a big job? Im still kind of new to the diesel world so any help is appreciated. Thanks. P.S. The oil seems to be running down the front of the motor and down the back of the motor cause my starter is covered in oil!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-08-2008, 10:10 PM
cookie88's Avatar
cookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to behold
The pump body itself is leaking? Not one of the fittings?
__________________
Scott - FTE moderator
01 F-250 Lariat, 7.3, ZF-6, NV271, -38R, SII splits, DI tunes, Custom fuel, 5" stacks, IDM140....and more little mods than I can remember.
79 Bronco- 7.3 IDI diesel project truck - AWM
  #3 (permalink)
Old 07-08-2008, 11:49 PM
It seems to be leaking on the drivers side. It looks to be coming out of the pump someplace. I couldnt see it leaking from the lines anywhere. Thought maybe there was a gasket somewhere that could be bad.......
  #4 (permalink)
Old 07-09-2008, 09:52 AM
plowhand's Avatar
Playing in the Dirt
plowhand is gaining momentum as a positive member of FTE.plowhand is gaining momentum as a positive member of FTE.
There is a gasket under the HPOP reservoir. Also make sure that you check the high pressure oil lines and fittings going to the heads, they can spray oil pretty far before it starts running.
__________________
95 F250, XLT, 2WD, 5 Spd, 4.10 l/s, SuperCab, Longbed. Beans Stage II's, Open air intake, EBPV gutted, SSX, downpipe, CAT gutted, 10K mod, shimmed FPR, GPR control switch, gauges (Pyro, Boost, AMPs, mechanical Oil Pres. & mech. Water Temp.)
02 F150 Super Crew, Lariat (Wife's)
81 Bronco with 460
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
