Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-08-2008, 04:01 PM
biggyg2 is starting off with a positive reputation.
actuator 98' ford explorer drivers side-intermittent issues
I recently replaced the drivers side actuator on a 98 Ford Explorer Sport.
The problem previously was with the door not unlocking without some manually force (pull the door knob up while trying to unlock it.). The problem was intermittent.
Well, the actuator was replaced and it still is a issue some of the time.
I've read posts on the linkage needing grease but there are very little moving parts.
Any suggestions on what to check next?
Gavin
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-09-2008, 06:41 PM
eallanboggs is starting off with a positive reputation.
By actuator I assume you mean the solenoid? You can use a DVOM to check power at the switch and also move it device manually to see if there is binding. Lubrication at pivot points helps with this kind of device.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
