Transmission Being Rebuilt.....
Took truck in this morning to have trans rebuilt guy calls me about mid-day and tells me that the truck has a 4R100 valve body in a E40D trans. Is that possible? I didn't think they were compatible, If not I guess I will be looking to get a new VB along with the rebuild. Any ideas?
My E40D is a E40/4R100 hybrid. I know the case is 4R100, so I imagine the valve body is as well.
When I swapped it, I had no dipstick. The original E40 wouldnt fit. I went to a local trans shop, they told me I had the wrong tranny. Called the outfit I got the trans from and they said get the 4R100 dipstick tube and run the trans.
Sure enough 2 years later it works great.
Its my understanding that they do that because the 4R100 has steel planetaries and stronger clutches. Then you just use the E40 controller deal that goes in the side.
You might have something like that.
brokedad
12-16-2012 06:28 AM
rockcrawler_101
08-22-2009 01:17 AM
shadetreemec
34
04-20-2006 09:38 PM
