Siphoning Gas F250??? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-08-2008, 12:47 PM
bikmop bikmop is offline
bikmop is starting off with a positive reputation.
99 Ford F250 4.3L V8 Triton Engine, Regular Cab. To replace the fuel tank, the manual advises to siphon tank, however, it does not say how. I've tried through the fueling tube but this unit has anti-siphoning devices preventing tubes to be inserted into the fuel tank. I've heard that disconnecting the fuel filter and letting the fuel pump drain the tank will work, but need confirmation? Any suggestions. I've sank the bed in the lake putting my boat in and it seems that I have water in the tank. Truck stalled
Old 07-08-2008, 01:09 PM
caprang's Avatar
caprang caprang is offline
caprang is gaining momentum as a positive member of FTE.
Helped a buddy one time do something similar. His wife filled the tank of his diesel truck with gasoline. We took the bed off (real easy with a couple of guys) and removed the fill hose from the tank. We did this because the tank was full and we knew it would be heavy to drop down. If your tank is under half full loosen the straps and start to lower it. When low enough to get your hand on top of it disconnect the hoses and wiring and you are free. Check out the tech section for the harpoon mod to the tank.
Old 07-08-2008, 01:20 PM
tinker934's Avatar
tinker934 tinker934 is offline
tinker934 is starting off with a positive reputation.
Quote:
WOW that was the hard way??? how about after the pump that is on the framerail disconnecting the line and turning the truck toe the on position and tada let the pump do most on the work at least that is how i did it for one customer.(and made him haul off the gas)(
Old 07-08-2008, 01:30 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Quote:
Anti-siphon devices? Anybody else heard of that? I've siphoned out of my '06 diesel with little problem - long story, and no, diesel does NOT taste good. Just wondering if anybody knows what might be stopping his siphon hose.
Bill
Old 07-08-2008, 01:38 PM
caprang's Avatar
This was a 99 we worked on. The separator/drain is on the engine, not on the frame. We didnt want to run gas all the way to the engine plus we needed to be sure we got 100% of it so no matter what the tank was coming out.
The original poster has a 99 gas truck (assuming a 5.4 since they dont make a 4.3) and I dont know of a fuel drain on a gas truck. Also, if he does have water in the tank I would suggest insuring it is 100% empty so he doesnt have more issues. Just my opinion.
Old 07-08-2008, 01:47 PM
bpounds's Avatar
2 bit Californian
I know he has a gasser, but I'm pretty sure the tank is the same for gas or diesel. The filler spout is different because it has to have the lead gas restrictor. I just have never heard of any anti-siphon gizmos. Why would they restrict siphoning gas, but not diesel. Flammable fumes? I was able to get a 3/4" garden hose down mine, with a little bit of twisting motion. Gasser might be different, but I would like to see some confirmation.
Regardless, to the OP, it is pretty easy to take the filler tube loose from the top of the tank. It looks like this on an '06:
BTW, your fuel pump is inside the tank. So you could take a fuel line loose anywhere and pump the tank that way. Just don't let it go too low or you risk burning up the pump.
Bill
OLD GAS epdukes13 1987 - 1996 F150 & Larger F-Series Trucks 8 08-08-2014 01:07 PM
24 Gallons of Unleaded Gas in my PSD VH_Girl 1999 - 2003 7.3L Power Stroke Diesel 27 07-13-2014 01:15 PM
fuel not reaching engine filter, filter being filled with air Orpackrat 1994.5 - 1997 7.3L Power Stroke Diesel 9 07-10-2014 10:53 AM
fuel siphoning problem ejmaso 1947 and Older Ford Trucks 31 10-16-2012 10:57 AM
Stealing my own Gas Knothole 6.2L V8 5 07-17-2012 09:00 PM
Tags
1999, 2006, 2008, 99, anti, diesel, f250, ford, gas, pickup, siphon, siphoning, spring, syphon, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
