Anyone here good with brakes??? - Ford Truck Enthusiasts Forums
Tennessee Chapter Join Chapter Leader:
Old 07-08-2008, 11:37 AM
Blue Bomber's Avatar
Blue Bomber Blue Bomber is offline
Blue Bomber is starting off with a positive reputation.
ive been having this brake problem for about 2 months now. ive replaced the master cyl. twice, the p- valve, some of the hard lines and the rear rubber brake line. but the rear drums keep hanging up. I think the rear pads have worn down to where it dosnt hang up as much, but i can still sit at a red light with out holding the brakes. I still have to make sure the rear pads are on right, but is there anything else it could be?
Old 07-08-2008, 04:45 PM
Nighthawk53 Nighthawk53 is offline
Nighthawk53 is starting off with a positive reputation.
After all you've done, the only thing I can think of is the parking brake cable hanging up. Or weak brake return springs in the drums. After 30 some odd years of loyal stopping service, I'd probably change the springs and all the other hardware in the drums.
Old 07-08-2008, 04:57 PM
I have a hardware kit on back order with one of the sponsors. I guess i could check the EBrake cable. But i though i adjusted it. How would I be able to tell if it is the EBrake?
Old 07-08-2008, 05:25 PM
Have your assistant mechanic apply the p brake and watch to see if the cable releases at both the adjustment Y and the drums. You may have to do this a few times to see all the points. Also something else to check would be the self adjusters.If they are difficult to turn with the adjusting finger pried away from it , it could need to be freed up. When you adjusted the p brake , did you adjust it to where it catches about half way... or does it catch at the top? It should catch or stop at about half way to the bottom.
Old 07-09-2008, 11:22 AM
oh really. i might have done it wrong. ill have to check today. ill be helping a friend fix his truck, so ill check. i knew i did something wrong.
thanks.
Old 07-10-2008, 11:21 AM
i didnt have time to get to it yesterday. ill try to get to it this weekend.
Old 07-10-2008, 04:33 PM
Just take care with it. Wouldn't want them to get too hot. If they are the glued on type they could come loose and really give you a STOPPING experience. I've been there before.
Old 07-10-2008, 04:39 PM
uuummmmmmm, Ive been driving it like this for about 4 weeks now. I dont think they are the glued type.
Old 07-10-2008, 09:09 PM
That's good....You musta got a good set. I hope that I've helped you with the project. I love to tinker with the older models. These newer ones are a pain to do anything with. Have fun with it. If I can help some more just let me know.
Old 07-11-2008, 01:49 AM
Greywolf's Avatar
Greywolf Greywolf is offline
Greywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputation
I always make it a point when I do drum brakes to tear down the self adjusters and clean them really well. When they go back together, I use lithium grease on the barrels and threads, then check to make sure they turn well.
All rubbing points need cleaning and lube too - the ones on the backing plate and where the ends of the shoes rub on the adjusters and anchor slots.
Last step when everything is assembled is a brake adjustment. Turn them all the way tight so the tire won't turn either way, then back off the adjuster until you barely hear them touch and don't drag with the tire being turned by hand.
If all this was done - the E-Brake is about all it can be.
Left Rear Brakes Hanging up Pocono Super Duty 1999 to 2016 Super Duty 10 07-15-2013 07:52 PM
Brake pedal goes to floor BNeu11383 1987 - 1996 F150 & Larger F-Series Trucks 5 12-12-2011 06:06 PM
Bleeding Brakes jleo Brakes, Steering, Suspension, Tires, & Wheels 6 04-04-2010 02:29 PM
Rear calipers hanging up? Tailspin 1999 - 2003 7.3L Power Stroke Diesel 5 03-07-2009 11:33 AM
2002 Mountaineer Brakes Hanging? danlee Brakes, Steering, Suspension, Tires, & Wheels 4 08-13-2004 07:15 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
