P0191 code on 5.4, had plugged filter, still have code - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-08-2008, 07:59 AM
jeffdoerr jeffdoerr is offline
jeffdoerr is starting off with a positive reputation.
This is on my e350 van, 05 with a 5.4. Just rolled over 100k and I was in VA in the hills with a load and I lost power. Barely (like 10 mph) made it to the top and then it was fine again. Did this every time I needed to climb a hill and was loaded. Will not lose power when empty, just loaded. I went to a chain autoparts store and had the tart there pull the code for me and it was a p0191. He looked it up and told me I had a bad fuel pressure sensor and that it was a dealer only item. So, off I went a few hundred more miles and it was still a problem, I went to a real parts store and I changed the fuel filter at the first chance and it was bad, looked like mud coming out of it. I also put in dry-gas and ran premium the rest of the trip. It was much better, but will still, ONLY WHEN LOADED, will lack power, like the engine is losing fuel.
The 191 code is a fuel rail pressure sensor, my question is are these sensors prone to failure or is this a diffrent problem ?
Old 07-08-2008, 08:25 AM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
Not sure if that is really the problem but here is a link to the removal/installtion of the senor.
2005 F-Super Duty 250-550 Workshop Manual
You may also want to look at your filter again. If you have that much gunk in it when you replaced it you may have got something in the tank and the new filter is plugged again.
Old 07-08-2008, 11:59 AM
I changed the filter a second time as soon as I got home and it was clean. thanks for the link.
Old 07-08-2008, 01:42 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
How is your fuel pressure?
08 F250 5.4 P0191 dhoff024 1999 to 2016 Super Duty 3 07-30-2015 11:58 PM
P0191 Frmtrk Modular V8 (4.6L, 5.4L) 4 02-24-2015 07:39 AM
05 F-250, P0191 only when hot under load Potskie 1999 to 2016 Super Duty 4 11-23-2014 09:00 PM
07 F-250 5.4 Running poorly under acceleration madMatador78 1999 to 2016 Super Duty 11 06-03-2014 08:32 AM
'08 5.4 losing power bayou barataria 1999 to 2016 Super Duty 22 02-13-2009 04:36 PM
Tags
05, 2005, 350, 54, 54l, code, e350, f250, f450, ford, fuel, p0191, pressure, rail, rangeperformance, sensor, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
