Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-07-2008, 11:56 PM
94MustangGT is starting off with a positive reputation.
Whats the deal with the recall on mid 90's+ vehicles?
My 96 F150 is blowing the #13 fuse and smoking the wiring attached to the master cyclinder. This had happened before and I thought I had fixed the problem by disconnecting the cruise control, and getting that new part/wiring harness that threads into the master cyclinder.
What did they do to fix the recalled cars? Ive only had the truck a few months, so I wasn't up to date on any recalls.
Any input would be helpful. I will try to get it towed to Ford tomorrow, but its backed in against a curb, and the #13 fuse control the shift interlock as well. Without the fuse in, hopfully it wont burn to the ground in the mean time. =/
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-08-2008, 08:22 AM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
There is no need to tow the truck. To bypass the shift interlock, turn the key forward one click, place the shifter in neutral, and start the engine. Then drive off. Procedure is in the owner's manual. Replacement manuals are downloadable from Ford's website if your original is missing.
You have to disconnect the connector on switch on the master cylinder, not the cruise module to protect the truck.
MANY previous discussions regarding the recall can be found by SEARCHing for keyword "05S28".
Check with your dealer. Certain vehicles got a harness that was improper for the vehicle and did not protect against a shorted switch. These vehicles were recalled yet again.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 07-08-2008, 09:10 AM
Thanks.
So leaving the wiring on the master cyclinder unhooked will not cause any the shorts, for sure? It was unhooked when I stuck a new fuse in, and it immediatly flamed up at the connector and blew the fuse.
__________________
96 F150 XLT - RC/SB - 351 - E4OD - 4X4 - 3.55's w/Rear Posi - Handling Package - Towing Package w/Super Cooling - Warn Manual Hubs
94 Mustang GT - 5.0 - 5speed - Black on Tan Leather - Bullitt Wheels - Bolt-ons
  #4 (permalink)
Old 07-08-2008, 05:54 PM
EPNCSU2006's Avatar
EPNCSU2006 is gaining momentum as a positive member of FTE.EPNCSU2006 is gaining momentum as a positive member of FTE.
It sounds like you have a short circuit unrelated to the recall. The recall was for the pressure switch in the master cylinder shorting to ground through the brake fluid, causing a fire.
__________________
Eric
'87 F150 302 manual 4sp overdrive 4x2
  #5 (permalink)
Old 07-08-2008, 09:45 PM
I drove to the dealership w/o any incidents( harness unhooked, no #13 fuse). Everything is going to be covered by the recall and should be ready tomorrow. Thanks guys.
__________________
  #6 (permalink)
Old 07-08-2008, 09:55 PM
Blurry94's Avatar
Blurry94 has a good reputation on FTE.Blurry94 has a good reputation on FTE.Blurry94 has a good reputation on FTE.
Quote:
That switch stays hot even when the engine is not running.
__________________
Matt C.
94 Lightning, blown/intercooled stock longblock, 1.76 60' 7.94 @ 90mph (1/8 mile)
01 F-150 4.6 2wd RC, K&N drop in, shorty headers, Flowmaster w/duals
  #7 (permalink)
Old 07-09-2008, 04:39 AM
EPNCSU2006's Avatar
I realize that, but from his description, the wire was melting even while unplugged from the brake pressure switch.
__________________
Eric
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
