Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-07-2008, 10:49 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of
2.3l Courier questions
I have a thing for asking strange questions-
I have an 81 Courier with the 2.3l Ford engine, and five speed manual.
Is the bell housing pattern used on this setup common to any other engine, namely the Mustang 200 small 6, or Mercury Capri 2.8 v6? I'm tired of an underpowered four cylinder-
__________________
Jared
The government said all my vehicle were too old to be clunkers
FTE Guidelines
  #2 (permalink)
Old 07-08-2008, 09:29 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
Sorry bud...the 2.3 is all it's own bolt pattern.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 07-08-2008, 08:45 PM
Ford_Six's Avatar
Figures- I did do a quick mod (literally five minutes) that allows me to now accelerate on the highway in fifth gear, and not have to downshift on small hills-
There is a little flap in the air cleaner nozzle, that closes when the engine is off to prevent gas vapors from escaping. Problem is, it closes when the vacuum drops, like when you have it floored, so it goes rich, hurts fuel mileage, and generally makes me hate the truck.
I pulled the vacuum motor, pulled the flap, and put the vacuum motor back in place- Now it actually accelerates up hills in fifth gear, and got quite respectable mileage on the trip home. Time will tell how much better mileage-
__________________
Jared
FTE Guidelines
  #4 (permalink)
Old 07-08-2008, 09:55 PM
TigerDan's Avatar
1968 Ford F-250
If that's still not enough for you, you could always go the 2.3 turbo route...
__________________
FTE Moderator
  #5 (permalink)
Old 07-09-2008, 01:35 AM
Ford_Six's Avatar
Well, I thought about that, but this engine would need to be pulled and gone through, since it burns a little oil already.
Right now, I'm investigating leads on a 200 or 250 and 4speed or maybe 5speed manual- While doing this swap, I would also be lifting the truck about 5" from stock height to fit real tires, so the loss of overdrive wouldn't be a big hit.
__________________
Jared
FTE Guidelines
  #6 (permalink)
Old 12-11-2008, 10:13 PM
human_fly_ human_fly_ is offline
human_fly_ is starting off with a positive reputation.
hey dan, can you talk a little more about that turbo route
Quote:
is there a turbo engine that is a direct swap-in for an 82 courier? i recently contacted a rebuilder to inquire about a reman 2.3L, and asked is it would accept a procharger supercharger, but the guy figured the stock crank might not support that power.
is there a better alternative than a reman, ported, polished, with a s/c? please let me know
  #7 (permalink)
Old 12-12-2008, 10:40 AM
TigerDan's Avatar
1968 Ford F-250
The 2.3 turbo from the T-bird, Mustang SVO, or Merkur XR4Ti is essentially the same as the N/A Ford 2.3 used in the Courier. The '80s T-bird version is the most common.
The main upgrades to the turbo motors to handle the boost were forged pistons and rods, but I believe they still used the standard cast crank that came in the N/A 2.3 engines, which is a pretty stout unit anyway. There are aftermarket forged cranks available (along with many other HP parts) as these engine are quite popular with the mini-stock racing crowd.
Here's a Courier turbo I found...not quite to my taste, but you get the idea:
laidoutcourier?s 1973 Ford Courier - Pictures, Ratings, Specs, & Modifications ? Mini Truckin Web
__________________
FTE Moderator
  #8 (permalink)
Old 12-12-2008, 03:14 PM
thanks for the link, got another question for you
Dan: what year would you think for an 82 courier? an 82 t-bird turbo? is it a drop-in job? need new motor mounts? was there a year that had bad casting for the block, or anything like that?
appreciate your advice!
bobby
  #9 (permalink)
Old 12-12-2008, 09:46 PM
Ford_Six's Avatar
Not to overtly promote another forum, but I did find his place a month o so ago:
Ford Courier Collector :: Index
Ford Courier Collector, lots of specific info there. There are a couple of turbo'ed Couriers on there, I'm on there.......
The oil burning thing seems to just be valve seals, so I may go the turbo route. Either that or swap out the engine and tranny for a 2.8v6 from a Capri or a 200 inline six from a Mustang. Who knows, I'm just driving the thing now.
__________________
Jared
FTE Guidelines
  #10 (permalink)
Old 12-14-2008, 11:09 AM
CooL!
Hey Man! Thanks for the amazing link!
bobby
  #11 (permalink)
Old 01-28-2009, 02:02 AM
Old Rob Old Rob is offline
Old Rob is starting off with a positive reputation.
Ford has only two crankshafts for the 2.3 lima. Large main journal and slightly smaller main journal. They were all cast and quite strong. Get ready to shell out close to 2 grand for a billit crank.Non turbo engines had cast flat top pistons, where as the turbo engines had forged dished piston. The engine mounting points are the same on all of the 2.0, 2.3, 2.5 lima blocks, so it can bolt right in. The electrical is a little harder.
Another alternative is a 289, 302 V8 with C-4 or 5 speed. I've done them.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
