At wits end!!
At wits end!!
OK...95 f250 7.3 turbo...last fall replaced injector o rings..within last 2 months started having problems starting it..got ipr rebuild kit..did that..no luck..just replaced fuel pump..no luck..used a squirt of starter fluid to get it running...it runs like brand new once you get it started..no problems at all..lots of power..no smoking..great..shut it off, that's it..no start..just turns over and over..no start...any ideas..I'm about to park this thing out in the field with the old tractors!! Someone told my dad maybe it's the hpop, it's there a way to check that before I buy a new one?? There's no lites or anything that comes on to give a clue as to what it could be...please give me some ideas!!!
Also check battery's .. these truck need to turn over fast to start, without a squirt of starter fluid.
It needed it first thing in the morning (winter or summer ) then it was good the rest of the day.
All I can say to that is play the lottery, looks like you have luck on your side!
I have seen the International / Ford 6.9 and 7.3's go BOOM a couple of times now, (well actually Bang, Bang, Bang, Rattle, Rattle, Rattle) $4k please...
Note: Other peoples, including a small dealer...
That was a few years ago Ive learned a little more now..........
Someone told me it was going to cost $2500 to fix and I decided I could buy alot of starting fluid for $2500.
But Ive used starting fluid on lots of diffrent engines, small engines, tractors , heavy equipment.
Sometimes its been the only thing that got them running.
It has its uses.
