1984 F150 Manual Transmission - Ford Truck Enthusiasts Forums
Old 07-07-2008, 05:57 PM
Dustincoc Dustincoc is offline
Dustincoc is starting off with a positive reputation.
What transmission is in my fathers truck? It's a 3-speed with overdrive manual. The engine is a I6-300(4.9l).
Old 07-07-2008, 06:22 PM
CheeseSteakJim CheeseSteakJim is offline
CheeseSteakJim is starting off with a positive reputation.
Probably an NP435 but more info is needed to be sure.
Old 07-07-2008, 08:26 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
A 4 speed OD is not the NP435.
This is PROBABLY the top shifted version of the Tremec built, redesigned for OD transmission originally known as the Ford T&C "top loader" 4 speed from the good old days. Pics here, first ones up:
Domestic Truck Tranny Guide
Top shift and aluminum case would ID it as the third one they describe.
Old 07-08-2008, 01:14 PM
I think that's what it is, I know its got an aluminum case and the floor shifter goes directly into the top of the transmission.
Old 07-09-2008, 08:27 PM
madmacs madmacs is offline
madmacs is starting off with a positive reputation.
Made by Mazda!!
Old 07-09-2008, 11:48 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The Mazda's were 5 speeds.
Old 07-11-2008, 09:10 AM
Mazda Trans in f 150
There were no 5spds in 1984 f 150s, the cast iron case outside linkage 3spd ODs were of American source the alum top loaded trans were made by Mazda. Don't recall when they began using the mazda trans, my 79 was cast iron my 84 is aluminum. Straight 5spds were not available until the redesign in 87.
Manual Transmission DieselOwnerNow 6.0L Power Stroke Diesel 6 10-10-2013 02:58 PM
5 speed manual transmission michbol Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 10-21-2010 08:03 PM
Auto trasmission to manual transmission conversion. terrylamar 1994.5 - 1997 7.3L Power Stroke Diesel 7 01-31-2010 06:40 PM
Transmission swap in 87 ranger joejoebo Ranger & B-Series 3 01-11-2010 11:43 AM
1984 F150 manual transmission Redone 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 04-30-2005 02:59 AM
Tags
1984, 84, f150, floor, ford, gallery, id, manual, overdrive, shifter, speed, tc, trans, transmission, tremec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
