4x4 CM testing??? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
4x4 CM testing???
Old 07-07-2008, 05:45 PM
epion04 epion04 is offline
epion04 is starting off with a positive reputation.
4x4 CM testing???
I have a 2001 ranger 4.0ohc, auto 4x4. the 4wd has not been functioning for quite some time, and i have narrowed down that the shift motor works properly, and that the is no voltage to its wiring harness. Due to cost is there a way to test the 4x4 control module and switch to narrow it down further before I drop a lot of money into this? Sadly i am on a limited time frame for the fix ( like i have one week to have the truck finished here in Illinois and be on the road for Arizona.) Any and all help will be greatly appreciated.
Old 07-11-2008, 05:24 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Have you checked the fuses? Also, if there is an aftermarket radio, they might have tapped for power where they shouldn't have-
Old 07-11-2008, 05:30 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Heres a list of 4x4-related fuses to check on your '01:
- Battery junction box (BJB) fuses:
1 (50A)
3 (50A)
13 (20A)
30 (10A)
- Central junction box (CJB) fuses:
28 (7.5A) (manual tranny)
10 (7.5A)
11 (7.5A)
5 (15A)
Measure the voltage between the control module connector pin 1 (OG) and ground; and between the control module connector pin 2 (DG/LG) and ground. Both should be approx. 12V.
Old 07-12-2008, 08:15 PM
thanks for the advice. got it fixed. after testing a ton of this and that i dug out the voltmeter and found i had no voltage going to the shift motor then tested the resistance on the switch. still good there. the motorola controll module was dead.
with the replacement of the 4x4cm and a DPFE sensor the truck seems to be back on its feet for the most part.
04 Ranger, rough idle Ranger Bob Ranger & B-Series 35 09-25-2016 08:46 PM
2001 transfer case motor (?) problems BigBlackF-250 1999 to 2016 Super Duty 0 06-19-2015 03:21 PM
99 Transfer Case Hall Effect Sensors Drumrkane Expedition & Navigator 2 04-14-2015 07:21 AM
truck won't start help me narrow down possible problems drewpyd85 1987 - 1996 F150 & Larger F-Series Trucks 14 08-15-2013 08:37 PM
Testing the P I P sensor Rackpatrol Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 08-02-2009 11:47 PM
Tags
2001, 2002, 4x4, 4x4cm, cm, control, ford, mazda, module, motorola, ranger, replacement, test, testing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
