Some sort of buzzer
Old 07-06-2008, 11:38 PM
DieselBeast01's Avatar
DieselBeast01
DieselBeast01 is offline
Some sort of buzzer
So today, i replaced all the gauge panel lights in my truck. After I finished up the job and reassembled the dash i noticed some sort of dinging. It would ding three times, pause for about 30 seconds and then ding again three times. After several rounds of this dinging it will stop all together, but once the truck is shut off and then recranked it does the same dinging. It is not the bell that goes off when the lights are left on or the door is open. It is a little fainter and has a different tone. Does anyone know what this is?
Old 07-07-2008, 09:13 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
No, but bumping because someone may know. Anyone?
Old 07-07-2008, 09:21 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
PETE'S_6.0PSD is offline
this might be cause one of your lights is out, so it dings a code , i think it might be an airbag one. check your airbag if it turns on when you turn the key, and check you passenger airbag light , by the off switch. , it might be an clock spring too...
250turbo's Avatar
250turbo
250turbo is offline
seat belt ?
kurt
Old 07-07-2008, 11:24 PM
DieselBeast01
about a year ago I had a little fender bender and the clock spring was knocked out...when i changed the bulbs in the dash, i purposely left the airbag light bulb out so that the airbag light wouldn't stay on. Is this what it is?
Old 07-08-2008, 05:20 AM
greedy737's Avatar
greedy737
greedy737 is offline
Seat belt, Door ajar, Parking brake? Don't know..
Old 07-08-2008, 06:10 AM
PETE'S_6.0PSD
thats what i said it will be, had the same problem...
change the clock spring and put the lightbulb it, its not worth your life few$$ worth of parts. and remember airbags save lifes, if your system wont work anymore you wont know it, and you risking not only your life but life of your family and friends. get it fixed....
Old 07-08-2008, 06:18 AM
just another truck's Avatar
just another truck
just another truck is offline
Originally Posted by 250turbo
seat belt ?
kurt
I a guessing here seatbelt as well.
Old 07-08-2008, 08:07 AM
Action4478's Avatar
Action4478
Action4478 is offline
Definately a chime to warn you of 2 problems ,,1 ,,SRS problem ,,& 2,The warning light is out...
Old 07-08-2008, 09:35 AM
DieselBeast01
Thanks guys for the help I'm going to go and purchase a new clock spring today.
Old 07-08-2008, 10:03 AM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
Clint,
Let us know what you find. I've read about this problem in other forums and nobody ever reported back with the fix.
Yougotthehit
1999 to 2016 Super Duty
03-07-2009 05:25 PM
RDC F250 7.3
34
12-07-2007 10:25 AM
mrpaintman
15
03-23-2007 08:47 PM
stockernavstar
20
02-11-2006 07:55 PM
Diesel Smoker
09-10-2003 11:43 PM
Quick Reply: Some sort of buzzer
