Has Anyone Used this Motorcraft Oil?
Motorcraft SAE 5W-20 High Milage Synthetic Blend Motor Oil
My Escape has 80K miles on it and wonder if this oil should be used or is it just hype. I have consistently used Motorcraft 5W-20 Synthetic Blend since I had the vehicle and never had a problem. What do these "high milage" oils have in them that make them different than regular oils?
I haven't seen this oil for sale anywhere, so I am presuming you can only get it at a Ford Dealership's Parts Dept. same goes for the full synthetic oil Motorcraft has come out with.
I don't have any oil leaks, so I think I will stay with what I am using.
I used Motorcraft syn blend 5W20 in my 4.2L F-150 on it's first two changes. The first change was at six months (1650 miles) and was done by the dealer. I did the second change a year later at 4300 miles. I was so impressed with this oil that I'm now using it in our two '03 Saturn VUEs (5W30) instead of Mobil-1. Don't ask me to quantify 'why' I like it better - all I can say is after having it on my hands and seeing how great it looks after a year in the truck, I just got a feeling about it that I'm going with. I can tell you this - because the oil plug is on the passenger's side of the aluminum oil pan on the vertical side, the oil shot out farther than I expected when I positioned the catch pan. The resulting oil spill area on the asphalt drive was about a square foot. Any other oil spill I've ever had was pretty easy to wash away, but I still haven't been able to get rid of that one. I've used all kinds of strong detergents with a stiff brush, and its still there after several attempts and several hard rains. That tells me something, know what I mean? So, for 80K miles and no oil use or leakage on your vehicle, I would advise to keep using the syn blend. If it ever starts using or leaking oil, you might try the special Motorcraft, but I would see no need for it now.
Speaking of the Escape automatic trans, what are you guys using? My son has one that seems to get 'shudder' not long after a fluid change, and I was thinking of getting him to use Valvoline 'Max Life' Dex/Merc ATF which is rated for just about every trans, including Toyota T-IV which is a very highly friction-modified ATF.
parkland
General Diesel Discussion
03-31-2014 06:06 PM
