Quote:
Originally Posted by lonerangerinaz
Using the wiring harnness that came with the truck so I can use the same PCM. Getting a custom hand held programer so I can retune the PCM to make up for the larger displacement so the engine wont run lean.
It won't run lean-the MAF will measure the amount of air entering the engine,and deliver PCM will deliver the appropriate amount of fuel to meet the commanded air/fuel ratio.
Now,when displacement changes-the calculated load will change. Ignition advance is based on calculated load,as well as transmission shift schedules and firmness-those will all be off a slight bit. It will be safe to drive it,and won't hurt a thing to do so until you get the tuner setup-it just won't be up to it's full potential until that time.
JL
