Non intercooled 05' roush charged 150
Hello guys, I have been informed that once we get a new truck I get our roushed 150 (sweeeeet), anyways its moderatly fast but i feel like it is held back. It is not intercooled so how much more boost can I run through it before it is unsafe to not have it meth/water injected? Are headers worth it on a s/c truck, because the ones i found are nearly 1400 w/o the custom run exaust, and with out my truck being intercooled how much horse power can i expect to get out of this motor before i start droping 2 or 3 grand? Well thank you all again
on
The $1400 for headers? The only one's I know of that are that expensive at the Dynatech long tubes which include a full exhaust plus Magnaflow high-flow catalytic converters. Long tubes are good for about 20HP at the wheels - and they should cost that much!
Troyer is a good choice for mail order tunes, even better if you can get by his shop locally. His 2004 F150 uses a non-intercooled Roushcharger (or did, last time I was there) so he knows them well, plus he's done countless intercooled Roushchargers as well.d
I would love to stop by his shop but im not driving all the way from wyoming to get a tune, but thanks for the replys. And the heders that you said were the ones that I was looking at, if I ran true duals with stright through mufflers would i have to worrie about backpressure? With his tunes would i need a tuner or would one be recomended? Would i need the exausht on before i get the tune? Thanks again guys
on
He handles tunes via mail-order but obviously they won't be as good as those done on the dyno with your truck. The headers I mentioned were true duals which included hi-flow catalytic converters, with or without mufflers. With true duals mufflers aren't going to cause any restriction on a non-intercooled truck. The tune needs to be written for the modifications the truck has. You can get it before the exhaust, but you'd need to get another set of tunes done after you get the exhaust. All tunes need something to load them on the computer with. On 2004+ you have to use a tuner. On 1996-2003 a tuner or a chip.
Maltman
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
09-04-2013 01:51 PM
'06Roush_150
12-13-2012 06:54 PM
kfx400_1124
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
04-21-2009 03:06 PM
150, 2005, 2006, charged, dyno, f150, f250, ford, harley, intercooled, nonintercooled, rousch, roush, supercharger, truck
