Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-06-2008, 08:04 PM
Frisco the Dog is starting off with a positive reputation.
blown turbo questions
Hello, I just blew my turbo. I`m running an sct tuner.
I`m about 50 kms from closest ford dealer and about 100 kms from BD diesel in abbotsford bc. How far would you drive with a blown turbo, I am towing a 20 ft cargo trailer with 2 quads and a bunch of other stuff in it
would you go to ford and just get a new stock turbo from them or go to BD for their aftermarket one, which would probably require more upgrades.
also would you try to drive it or get it towed
any help would be appreciated
__________________
2007 f350 6.0 cc sb 4x4 lariat black w/ sunroof,linex, retrax box cover, alpine stereo, python 2-way remote start, sct custom tuning, 4" flo-pro dual exhaust, 35" toyo mt,bushwacker fender flares, stock height, bilstiens, rancho single stabilizer.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-06-2008, 08:13 PM
Sarge261 is gaining momentum as a positive member of FTE.
When you say blew the turbo I am assuming that it jut builds no boost, or does it over boost. I know that when my I/C pipe blew off it had no power so I would say check that first. Aslo there could be a crack/split in the intercooler as well, so check those too. Also what year is your truck and anyother symptoms you could describe may help us help you. As for an A/M turbo, I believe that you are correct in saying you would need other upgrades but I am not too sure on that as I havent done my research. Also you may beable to get i covered under warranty if it still has one.
I would tow it as these trucks are absolute dogs without a turbo. I am not sure if any damage can occurr by driving it without a turbo other than it couldnt pull a greasy string out of a cats a$$.
Good Luck
Sarge
__________________
2006 F-350 PSD Lariat Crew FX4 ALL BLACK
Banks Techni Cooler
Banks Big Mouth Intake Pipe
Banks High Ram Intake
Banks Monster Exhaust Turbo Back
BD Diesel Exhaust Brake
BD Diesel Torque Converter Pressure Controller
Air Ride Air Bags
Deep Sump Trans and Rear Diff. Pans
No-Shrink Tonneau Cover
  #3 (permalink)
Old 07-06-2008, 08:22 PM
when it blew it sounded like a tire blowing out (sort of) I was towing my trailer up a hill. It now produces zero boost.
I drove it down hill with hazard lights about 20 kms back to hope bc where I am now. Down hill it was no problem but uphill I had to floor it just to get to 50kmh.
The drive the rest of the way will be fairly flat but I`ll be on the trans canada hwy. with a speed limit of 100kmh.
__________________
  #4 (permalink)
Old 07-06-2008, 08:26 PM
Go out and check the I/C hoses. Thats what happened when mine blew off. Look around the intake elbo where the hose and elbow meet for oil spray. If there is spray there the hose has come off. Also look down at the intercooler and see that one too. Give it a tug you may find that is all it is. I am sure that the turbo hasnt blown. I am also sure that you may have bown the I/C hose off. Alos what year is your truck?
Sarge
__________________
Banks Techni Cooler
Air Ride Air Bags
  #5 (permalink)
Old 07-06-2008, 08:34 PM
thanks sarge its an 07 with 80000kms on it, I do have extended warranty but I already had a head gasket repaired under warranty because of my tuner so I definatley will be repairing or paying for it myself.
I`m going to head outside now to check the hoses although I`m not 100% sure I`ll be able to figure out exactly what I`m looking for.
I definately saw some black oil around the turbo area when it first went
__________________
  #6 (permalink)
Old 07-06-2008, 09:01 PM
Look right next to the coolan fan shroud,where it says Power Stroke in red leters, there is an elbo right there and a boot and a pipe. The clamp on the boot probably loosened up and caused the pipe to come out of the coupler under high boost. If that is the case you nees to remove the intercooler pipe, and the coupler to the intake elbow and clean it with brake parts cleaner and then reassemble it. DO NOT put any lube on the pipes or coupler as it will pop off again. If that is not the problem, follow the pipe down to the Radiator area and check the intercooler itself. Some have ad the Plastic tank separate from the fins. Check both sides as I have never seen picturs of where this breaks.
Hope this helps and you can fix it where you are. I will check back in the a.m. to see how you made out.
Sarge
__________________
Banks Techni Cooler
Air Ride Air Bags
  #7 (permalink)
Old 07-06-2008, 09:25 PM
Well Sarge I would like to say thank you a thousand times.
The clamp had come off of the boot where the intercooler connects to the pipe between it and the turbo, basically right where you said.
Can the tuner cause this or could it happen with or without one
Regardless, once I get home on to my own computer I will become a supporter to this site as it has helped me out on numerous occasions
Thanks again!
__________________
  #8 (permalink)
Old 07-06-2008, 10:22 PM
SteveBricks's Avatar
SoCal Chapter LDR
SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.
Way to go, Sarge - reps sent your way.
__________________
Steve
06 King Ranch CC 4WD PSD
94 F350XL CC 7.5
SoCal FTE
Join our Chapter *HERE*
  #9 (permalink)
Old 07-06-2008, 10:35 PM
mxer0022's Avatar
mxer0022 is starting off with a positive reputation.
Quote:
that makes 2! that deserves a big ATTA BOY!!!
__________________
"Ford, Because Driving A Chevy Will Give You Herpes"
2006 F-250 6.0L powerstroke cc 4X4
black leather interior
captains chairs
Amarillo special edition
westin brush guard
MBRP cat delete
Fumoto Valve
MBRP turbo back and Phantom II gauges shipped
lots of chrome..haha
tune coming soon
  #10 (permalink)
Old 07-07-2008, 09:03 AM
Thanks guys but I dont know what REp Points are.... I really appriciate it.
Thanks Anyway
Sarge
__________________
Banks Techni Cooler
Air Ride Air Bags
  #11 (permalink)
Old 07-07-2008, 12:02 PM
dave at BD Power's Avatar
FTE Sponsor
dave at BD Power is gaining momentum as a positive member of FTE.dave at BD Power is gaining momentum as a positive member of FTE.
Frisco,
BD is not only a performance turbo builder we are also a complete OEM turbo rebuild facility as well. If you can get the truck here we have some great pricing and will take care of ya!
Dave
__________________
FTE Sponsor - BD-Power
03 Dodge Ram 2500 2WD Reg Cab
BD X-Tuner stacked with BD X-Power
BD Super-B Turbo & Dual X-Hale Exhaust
BD Max Flow Lift Pump
Ice Box Cold Air Intake
www.dieselperformance.com
dave@bd-power.com
800-887-5030 ext. 105
  #12 (permalink)
Old 07-07-2008, 02:03 PM
Frisco,
It can happen with or without a tuner, Just clean the pipes and boot real good with some brake clean and you sould be good to go. Also go to the tech folder and do the CCV reroute and that will help with all the oil in the intake which will help eleviate the pipe blowing off. As BD said get the truck to them and they will hook you up with some of those upgrades you have questions about.
Thanks for the Rep Points guys...just doing my job
Sarge
__________________
Banks Techni Cooler
Air Ride Air Bags
  #13 (permalink)
Old 07-07-2008, 04:03 PM
FTE Sponsor
IMO... our CCV kits are one of the most under rated products we sell, it works great and looks like a factory install. Having a boot blow off is pretty common, especially around here and too often a bad start to a good weekend trip.
__________________
dave@bd-power.com
  #14 (permalink)
Old 07-07-2008, 10:42 PM
bismic's Avatar
bismic has a very good reputation on FTE.bismic has a very good reputation on FTE.bismic has a very good reputation on FTE.
Quote:
I agree that this is a GREAT mod! Highly recommended!
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
  #15 (permalink)
Old 07-08-2008, 06:58 PM
otea090 is starting off with a positive reputation.
Anyone use BD's CCV kit? I've been thinking of doing the reroute but would like a clean install w/ some sort of a filter so it's not dripping on the ground. Sounds like you found the problem Frisco. I've also had boots blow off 3 times and that was before getting custom tunes. I was stock. Watch for overboosting if you have a guage. You may have a sticky turbo.
__________________
Randy, 04 F350 FX4 CC LB SRW Lariat, 56K, Add-a-leaf front, Firestone bags rear, Dieselsite coolant filter, 05 grill
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
