Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-06-2008, 06:12 PM
second chance is starting off with a positive reputation.
Whats going on here?
What size injectors came out in a 95 F-150 , 302 with the speed density? I was told when I bought the truck that the injectors were out of a Mustang Saleen. Here lately my truck idles about 1600 when I start it in the morning and continues until it gets good and hot, also it will surge and die when it takes a liking to, along with feeling like a miss, however I don't feel that it is electricial. Bad injectors? I did get some eytanol in my fuel a while back. HELP!!!!!!!!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-06-2008, 07:01 PM
quicklook2's Avatar
quicklook2 has a good reputation on FTE.quicklook2 has a good reputation on FTE.quicklook2 has a good reputation on FTE.
vacuum leak?
iac failing?
__________________
“It is wiser to find out than to suppose.” ~Mark Twain
  #3 (permalink)
Old 07-06-2008, 10:46 PM
e1p1's Avatar
e1p1 has a good reputation on FTE.e1p1 has a good reputation on FTE.e1p1 has a good reputation on FTE.
If you have access to a fuel pressure test gauge, test the pressure at the rail schrader valve. A bike pump w/gauge has worked for some. The fuel pressure regulator (FPR) is a known source of problems. Fuel pressure should be steady around 35 lbs, a few more under wide open throttle (WOT). (Mine was at 80+ lbs, similar symptoms).
It's an easy test to perform, and good to rule the FPR in or out early.
Also check all the vacuum lines, especially those to the EGR. Also, the white plastic vac lines near the firewall on the passenger side are known to get brittle and cause surging/missing. If one is bad, cut out the brittle part and use a vacuum hose with an id that slips over the white line to patch it.
Also check the canister looking thingy (that's a tech term)...if it's metal it might've rusted with pinholes.
__________________
Braccae tuae aperiuntur
'93 F-150 4x4 Supercab Longbed, 5.0L, AOD, BFD...No Mods.
'94 Lincoln Town Car
'93 Taurus Wagon, 3.8L . Dog is my co-pilot.
  #4 (permalink)
Old 07-07-2008, 11:21 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
The injector tops should be orange 19lb(depending how badly faded they are they may look sorta yellow), If they are blue or any other color you got the wrong ones and you need to change them out with orange ones.
Start by cleaning the IAC valve and check for stored codes.. Ford Fuel Injection
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
