07-09-2008, 04:59 AM
yes, replace the crank pulley key.
also replace the front crank seal. may or may not come with the front cover gasket as a set.
replace the crank and cam gear plus the chain, the tensioner and chain guide. Cloves makes a set with all. 3L does not have tensioner and guide
front cover gasket sets come with cover gasket, water pump gasket, front crank seal.
examine the vibration damper front seal run area for a wear groove from front seal. if worn, replace the damper or use a Timken Quik Sleeve repair seal kit
examine the crank end and the pulley hole for wear. when you put it back on, make sure the pulley is tight on the crank and with NO wobble.
drop the flywheel tranny inspection cover or remove the starter to jam the flywheel with a piece of wood on the fw teeth and block
tighten the front crank bolt to specs with a torque wrench only. too loose is dangerous and too tight can cause the end of crank to snap off.
