Quote:
Originally Posted by pracing6
i have heard that a few gallons of gas will not hurt the truck if there is enough lube and diesel in the tank?
Not true!! The flash point of gas is very high and this will stretch your head bolts or lift your head off if you keep pushing it through. I'm not one to tell people what they should or shouldn't do, but if it were me, I would have drained the tank right away as previously suggested!! You are gambling with a losing hand!!
You can get away with running a little diesel through your gas engine, but rarely get away with running any amount of gas through your diesel!!!
