Yesterday when I turned it on the light on the monitor was flickering, and it took a little longer than normal to show the screen. This morning it would not come on at all. All connections were tight.
I don't know anything about these things, other than the fact that that one doesn't work any longer.
That's the only way I know how to fix the problem. The thing is warrantied for 3 years - guess I'll have to dig out the "original packaging" and the receipt and send it off to get it replaced or repaired.
They are getting cheaper and cheaper, and I don't think it's a coincidence that I'm seeing more of them fail within the first year.
If you turn the monitor off with the power switch, then turn it back on, do you see an image for a moment and then it goes black? If so, that's the back light failed. It's actually a tiny, about 3/16" diameter, flourescent lamp the same length as your monitor is wide. Just about every one I see fail has that problem.
