Hello All.
How it began: I was exiting highway and truck started acting like it was running out of gas. I quickly switched tanks to no avail. It was still idleing very low and only as long as I was feathering the gas pedal. It died and I've only been able to get it started once since then, after replacing the fuel filter, and it only ran short time at low idle with me feathering the pedal again. No start since.
I also could get it to idle on starting fluid, until it backfired due to starting fluid overuse. Now it won't even attempt to start with or without starting fluid. Just cranks!
Here's what I've tried: I replaced the fuel filter, tried different relays, and replaced fuel pump that is located on the rail. I also cleaned battery terminals and wires real good. I've changed the map sensor, checked for spark(it's good), checked the inertia switch(It's good), pulled the EEC-IV out and visually inspected(appears ok).
I can hear pump in tank energize and can feel the pump on the frame rail energize. It's not loud like it used to be though. Used to hear it energize from in cab.
I
DO NOT have pressure in the system though. I've used the relief valve after each start attempt and barely get any fuel to come out.
Thanks for any help as I am stumped.
Ken
