Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-06-2008, 07:34 AM
EricJ is starting off with a positive reputation.
65 P/s ?
I may have been mislead by a couple of photo's I came across.
Is the 65 P/S setup a powered box, or the valve and power piston type?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-16-2008, 06:02 PM
Roger Carter is starting off with a positive reputation.
Hello,
The '65 power steering was a powered box, typically referred to as a Bendix box. Ford used this set-up until 68-69, when they went to a Ford box. They used the same Ford box thru 1979.
Hope this helps.
Roger Carter
  #3 (permalink)
Old 07-17-2008, 02:36 PM
PROSTOCK is starting off with a positive reputation.
The P/S box up '79 will bolt in but you will have to shorten your steering column, or buy one from donor truck.
__________________
'65 F-250 Custom Cab 352FE 2WD
PS, PB, C6, 3.73 Dana 61('81 F350)
'02 Excursion Limited V10 2WD
Bilsteins, Tekonsha P3
  #4 (permalink)
Old 07-17-2008, 06:03 PM
so the bolt on is 65-69 2wd? is it 100 only or 250-350 also?
  #5 (permalink)
Old 07-17-2008, 07:54 PM
Eric,
The 65-69 Bendix box is the same for F-100 thru F-350 2wd. Most of the time it is a bolt in, due to the tolerances Ford built into the truck. However.... and I found the exception on the last Bendix conversion I did, The steering shaft was too long. Checking the parts book I found that the steering shaft on 65-66 P/S truck was about 5/8" shorter than the M/S shaft. I had another steering shaft I was able to shorten and install, then it was a bolt in.
Be sure to check pulley alignment between the crank pulley and the P/S pump. There are differences there also, but that is a story for another time.
Hope this helps. Good luck.
Roger Carter
  #6 (permalink)
Old 07-18-2008, 09:19 AM
Bolt-on is also thru '79 2wd.
__________________
  #7 (permalink)
Old 07-18-2008, 11:55 PM
iiizman is starting off with a positive reputation.
My bendix box sucked, so I got a saginaw box and its great and they are alot cheaaper. They are right had to shorten the Column a couple of inches.
  #8 (permalink)
Old 07-19-2008, 08:15 AM
Quote:
Originally Posted by Roger Carter View Post
Eric,
Roger Carter
I have a 390 sitting on the shelf that has the p/s pump on it. There is nothing wrong with my 352, but you can never have too many cubic inches, so I'll probubly swap that in when I find a steering box.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
