Column Choice
Column Choice
I need some opinions , pro's and cons,or any other advice for choosing the right column. Flaming River's or Ididit's tilt , polished aluminum column. Why is Ididit so high compared to Flaming Rivers. Which looks better to ya and which one will be best choice. I just cant figure this out by myself. Help please!
I like my truck for what it is, and am not building a "street rod" truck with a lot of modern aftermarket parts. The stock steering column will be cleaned and painted, and it will look better to me than any aftermarket column.
On my truck, a polished aluminum steering column would look out of place. (And nothing spoils the looks of a traditional hot rod's interior more than a flat-sided chunk of polished aluminum the size of a soup can between the dash and the steering wheel.)
I don't mean to shoot you down in flames (or scallops). I bought an old truck because I love old trucks for what they are.
Dave
1956 Ford F-100 panel truck project
Dave
I have had both Flaming River (in truck now) and Ididit. I think the Ididit column is a better built unit.
I have a volare front susp and at the time it had a lokar floor shifter so I bought a Ididit column with no shifter (it is about 2 inches in dia). Made all the brackets and bought some expensive floor mounting coller. Drove it and just hated the floor shifter swinging in the air (it was there when I bought the truck). So to save some of the stuff that I had bought I replaced the Ididit Column (2 inch dia floor shift, with column shift 2 1/4 dia) with a Flaming River (column shift 2 inch dia).
If I were to do it again I would modify the stock column, reason being I never move the steering wheel and the right position for me happens to be in a non tilt position.
Chuck
Chuck
I have the Ididit chrome, at the time i purchased I think the comparable flaming river was a little higher. I like the Ididit, was reccomended 32" length but when I installed with my seats it was a little too long, found it was easy to dissasemble and cut shorter, fits well, also was able to get an old style 3-bolt steering wheel adaptor so I could use my old "Superior" walnut steering wheel...just my 2-cents worth.
have a great day, Ed
Speedway motors sells some really nice old style steering columns priced reasonable. They have a 30" polished stainless steel column"it can be painted"with ball bearings on either end it comes with a double D end for a good mechanical connection to your steering box. it has no frills or thrills, it has a 3 bolt hub you can mount a grant wheel to it. Also the hub has a quick release so when your in those not so great places you can take the steering wheel with you, you know sort of a theft deterrent. They come in different lengths. pricing starts at $119.00
Hey Garry how are you.I am going to buy a column soon and I am not sure what length to buy.What length did you use.I am using M11 suspension.Hope you had a great holiday weekend.
