Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-05-2008, 04:16 PM
ttabol is starting off with a positive reputation.
'03 F250SD - hiss during acceleration???
Just got a F250SD with V10. During acceleration from stop, I notice a "hiss" which seems to come from the engine compartment if I'm not either going really easy or pushing hard. It almost sounds like a blow-off on a turbo motor. Any thoughts? Thanks!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-05-2008, 09:57 PM
Bulldog66 is starting off with a positive reputation.
It's that V10 telling you it wishes it was a PSD.
  #3 (permalink)
Old 07-05-2008, 11:15 PM
It might just be! I wish it was but couldn't pass up the deal.
  #4 (permalink)
Old 07-06-2008, 02:19 AM
i eat hybrids's Avatar
i eat hybrids is gaining momentum as a positive member of FTE.
Does it only do it when it is cold? If so, then ur missing a stud on ur exhaust manifold.
__________________
  #5 (permalink)
Old 07-06-2008, 09:03 AM
Actually, it seems to do it more when it is warm. It occurs most often between the 2nd to 3rd shift.
  #6 (permalink)
Old 07-06-2008, 05:01 PM
carls 250 is starting off with a positive reputation.
Are you sure you don't have a cat. plugging?
__________________
06SD 4x4 Lariet SC 5.4 auto.3.73LS Dark Shadow Gray W/Medium Flint Leather
  #7 (permalink)
Old 07-06-2008, 11:28 PM
I'm not sure about the cat...there seems to be no performance issues, no over heating, nothing else strange, just the weird noise which is clearly heard from in and outside of the truck. If I back off the gas just a bit or push down just a bit it goes away???
  #8 (permalink)
Old 07-06-2008, 11:40 PM
rebelyell618's Avatar
rebelyell618 is starting off with a positive reputation.
i'm going to watch this cause my 5.4 did the same thing (or something similar cause i had a high pitched hissing sound) friday. it only happened once when i was doing 60 mph once i pulled off the road the sound went away and hasn't occured since.
wierd thing is i just changed from 5W30 motorcraft oil to 5W20 motorcraft oil on thursday so wonder if that has anything to do with it.. wouldnt think so but the only other new part with me is a goodyear gatorback belt and a carquest air filter. i doubt that is the cause.
__________________
2000 Ford F-250 Crewcab Shortbed 4X4 5.4, 4.10 gears
stock height (for NOW), T3 grille guard with hella lights, cherrybomb extreme muffler, cb and satellite radios, many minor mods with more be putting on everyday.
  #9 (permalink)
Old 07-07-2008, 08:06 AM
A saw a post via Google that suggests checking out the air filter/assembly. I'm going to try and look at this tonight...
Rebel - maybe it is the air filter?
  #10 (permalink)
Old 07-07-2008, 08:08 AM
sportscar's Avatar
sportscar is starting off with a positive reputation.
My 04 V10 does that...since new, even with a new air filter.
__________________
2004 F-250 SC V10
  #11 (permalink)
Old 07-07-2008, 09:07 AM
5.4L to Freedom's Avatar
5.4L to Freedom is starting off with a positive reputation.
My 5.4 does the same thing, I think it's just the nature of these beasts... just cam noise, fan, tiny exhaust manifolds, and air intake assembly all working together to make a unique sound.
Keep in mind if you have the stock intake you a pulling a reasonable volume of air into that motor thru a relatively small tube, and as the air is pulled into the intake tube it's going to make noise, plus the high velocity of the air over the flex section will make noise too.
I would only get concerned if the hissing all of a sudden stops while it's running
ALSO the alternators make a bit of noise as they age, not to say it's goign bad, but that makes a bit of hissing as well
__________________
04 Super Duty Lariat FX4
5.4L-2V, 4R100, NP273, 3.73 LS
RanDOM CapS locKER!!! The latEST ADVANCEMENT iN e-TracTION techNOLOGY
Last edited by 5.4L to Freedom : 07-07-2008 at 09:08 AM. Reason: thought of somethin
  #12 (permalink)
Old 07-08-2008, 01:43 AM
Crummy 450's Avatar
Crummy 450 is starting off with a positive reputation.
I had a small seal not seat correctly on the intake air temp sensor in my Saturn, and it caused that same kind of hiss. I've had a similar issue with my van too, though it was a small crack that formed in the intake tube causing a whistle. Check your intake tract over carefully for any leaks. If you do find one after the MAF, you should sort it out pretty quick, as it may give you grief.
  #13 (permalink)
Old 07-08-2008, 10:43 AM
If it doesnt do it when its cold then u dont have an exhaust leak. Someone on here a while ago mentioned somtnhing about the heat shield on the y pipe movin around. Does this sound plausible?
__________________
  #14 (permalink)
Old 07-09-2008, 01:47 PM
Actually, I could be. I call it a hiss but a vibration on that thin metal could produce a similar sound. I'll give that a check. Thanks!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
