Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-05-2008, 02:43 PM
YenahsYenzow is starting off with a positive reputation.
Cool Tranny quit working right, need advice
Hello guys, i'm not a tranny expert myself...but do need an advice!
I own a 78 F-250 Supercab 2wd with a 351m/400 v-8
One day i was driving down the road and decelerated the truck towards the red lights and was trying to shift over to Neutral and accidentally put it in reverse and the motor died. I restarted the motor and it ran fine then shifted it into Forward and the tranny seemed to shift into gear, however it didn't move but just barely moved along with engine revving high. I suspected I broke something inside the tranny and have done a check up on rear end axle gears and rods they seem to be intact and not broken. driveshaft seems good and tried rolling the shaft to see if tranny and shaft is hooked up (i took off the filter part under the t ranny to do a check) and seems to be intact (only managed to see the half part of the tranny before the torque converter and seems to be intact) I suspect it would be the torque converter...what do you think?
Because I would like to know whats wrong in general first so I might have to get the motor/tranny pulled out. (fluid level was full before I removed the filter part)
Thanks
Shane
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-05-2008, 02:53 PM
Dr. Dirt's Avatar
Dr. Dirt is starting off with a positive reputation.
now on the new cars they have the feature where they automatically shift into neutral when stopped at a light to save gas. that's a good thing but if you're gonna do that do it when your truck is completely stopped. if you are still rolling and you take the truck out of gear you can burn up the gears. I used to do that and my dad told me what could happen so I stopped. sorry I can't help you with the real problem......good luck.
__________________
Kevin
1979 F100 4x2,
300 Inline 6,
3 speed manual,
9 inch rearend,
10 series Flowmaster,
Grant steering wheel,
JVC stereo in the glove box-the previous owner did that,
and some other stuff
"You got to drive that Ford like it's a stallion."-Jack Ingram & the Beat Up Ford Band
  #3 (permalink)
Old 07-05-2008, 08:55 PM
mudslingin'78's Avatar
mudslingin'78 is starting off with a positive reputation.
It sounds like you've messed up your clutch bands. Does the transmission eventually shift or does it stay in first revving.
  #4 (permalink)
Old 07-05-2008, 09:20 PM
jlk5269 is starting off with a positive reputation.
You may have damaged the stator in the torque Convertor, clutches or bands. It sounds like you must have a C-6 Auto.
  #5 (permalink)
Old 07-05-2008, 10:06 PM
its an auto from what i know, not sure precisely what model as i havent looked into it yet. it stays revving in first i believe...i couldn't tell since my muffler just blew and gotten pretty much noisy enough and couldn't hear the problem from the tranny. I strongly believe the gears arent busted because I could feel it shift into gear either reverse and forward...and seems to slip either way no matter how high I rev. I certainly believe it has something to do with the Torque Converter though.
Am thinking about just getting a used tranny from somebody for $100 bucks and have it swapped instead of $1,500 at a damn shop.
P.S. my computer internet is down as of the moment...will be using wireless somewhere close to home to get back to you guys so it will take awhile.
  #6 (permalink)
Old 07-05-2008, 10:50 PM
Tedybear is gaining momentum as a positive member of FTE.
Put the truck into MANUAL LOW. There is a chance the one way roller clutch ate itself. If the truck all the sudden moves forward under normal power? The roller clutch is shot. (manual first bypasses the one-way setup and applies full power to the clutches/bands used).
From the sounds of it? While normally I'm the last person to suggest torque converter failing? There is also a one-way clutch built into the torque converter to direct the fluid coupling action for max torque/power at the right points. At this point--looks like the transmission and torque converter should be replaced or rebuilt.
Taking a moving forward car/truck and slapping it into reverse at anything but a crawl can do. I understand it was an error to do so (I've seen people do it intentionally to show off). However the extreme pressures inside the transmission moving forward--and then suddenly into reverse? It would not surprise me to find internal damage to either a clutch pack or it's actuator...heck that much force would be enough to snap a band as well.
Check Car-Part.com and enter in the information. There might be one at a salvage yard in your area for a quick replacement. Rebuilding is an option also to be considered, however it would REQUIRE a new/rebuilt torque converter (it's foolish to attempt to reuse the old one, as any trash got dumped in there). You really won't know the full story until it's torn down if you rebuild it.
At this point, might be best to locate a good used one.
S-
__________________
The old girl is as follows:
1975 Ford F250 Camper Special
Normal Cab.
Rear Wheel Drive.
360 CID.
Auto Transmission-C6
Last of the vin: W69956
New ol' girl:
1989 Ford Bronco II XLT
2.9 V6
RWD
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
