How to test Blower Motor Resistor ?? - Ford Truck Enthusiasts Forums
Old 08-22-2002, 02:19 PM
Dogdecur Dogdecur is offline
Dogdecur is starting off with a positive reputation.
Does anyone know how to test a blower motor resistor? My blower only works on high, so I pulled the resistor and checked it with my voltmeter.
My truck is an '82 F-100 and the resistor has a three connectors then one single connector. Using my voltmeter, 2 of the 3 connectors show continiuity with zero resistance when I used the single connector as the other point. The other one (of the 3) also showed continiuity, but at a higher resistance.
I know a bad resistor can cause the fan to only operate on high, but before I replace the resistor, I want to make sure that is the problem.
Any experience out there? Does anyone know if NAPA, or other parts place carry this resistor?
Thanks, Steve
Old 08-23-2002, 04:42 PM
Charles-65F350 Charles-65F350 is offline
Charles-65F350 is starting off with a positive reputation.
You need an ohmmeter with a good low-resistance range to measure the actual values. Those resistors have values around a few tenths of an ohm. If you are reading continuity at each end of each "coil" they are almost certainly OK. Of course if there is a burned area and the ends are just barely touching all bets are off, but you could see that easily.
The other two-lead widget is a thermal fuse which opens if the resistors get overheated (for example, if a mouse nest in the heater box catches fire. Don't ask how I know). If it's open I believe you will not get any fan including high.
My Ford dealer has them for my '84 F150, for $23. Pep Boys, etc. did not.
Old 09-02-2002, 10:36 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
Post How to test Blower Motor Resistor ??
Old 09-05-2002, 12:41 PM
Thanks Charles,
Got it up and working, it was the resistor. Thanks to your info I was able to pick out one at a junk yard. It does appear that the thermal fuse had blown on my old one. I was able to test the junkyard's resistor and the old coils all had low resistance (less than 2 ohms).
I called my dealer and they wanted $50 for one and it was not returnable on top of that. The junkyard resistor cost me 5 bucks plus the time it took to pull it out!
Once again Thanks, Steve
Help with blower motor. 03F250SD 1999 to 2016 Super Duty 2 04-26-2015 01:42 PM
blower motor resistor connection relly 1968-2013 Full Size Vans 8 12-17-2014 08:58 AM
blower motor resistor dfiske Cooling, Heating, Ventilation & A/C 34 11-27-2013 01:32 AM
Blower Motor Resistor ljutic ss Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 06-04-2008 01:36 PM
damn blower resistor blew again what the heck buzzer 1987 - 1996 F150 & Larger F-Series Trucks 6 05-18-2004 12:01 AM
Tags
01, 2005, blower, f250, ford, forums, motor, ohms, ranger, replace, resistor, taurus, test, testing, voltmeter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
