Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-04-2008, 04:38 PM
AKFORD4x4 is starting off with a positive reputation.
Radiator upgrade!
Hey guys, I was tired of my truck running a little on the warm side while in traffic or crawling on a trail a 2 mph so I found a radiator from an 84 Diesel. Its 4 core and about twice as big as my radiator now. Anyway, They bolt right in, your truck has the factory holes just waiting to be filled with this radiator. Anyway, awesome upgrade for the cooling system, my truck runs nice and cool even on the hottest days or under the hardest loads. I also got another tranny cooler and piggybacked it into my existing cooler and now I have 2 tranny coolers to keep my C6 alive, about a 10 minute upgrade also. HEAT is the number one killer for trannys and many other components, soooo KEEP IT COOL
__________________
1982 Step side F-150 4x4, 351W, C6, Np 208, 9" rear axle, 4.10's, 6" Superlift stage II suspension lift W/long beefed radius arms, Superruner steering kit, 35" BFG's on 15x10 Aluminums, Performer intake, Holley 600 CFM carb, dual Hella's etc etc
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-04-2008, 04:55 PM
81-F-150-Explorer is gaining momentum as a positive member of FTE.81-F-150-Explorer is gaining momentum as a positive member of FTE.
I also did this upgrade to my 1981.
I put the full super cooling Radiator in mine.
The Radiator support will bolt a narrow or wide radiator in place.
However, it is adviseable to swap radiator supports on truck with the narrow radiator, because the narrower radiator support has a smaller opening up front than the "wider" support does. The extra opening for the larger radiator lets more air to the fins, therefore cools even better.
Then you can upgrade the fan guard to a fan shroud, and replace the flexfan with a fan clutch as well.
Very happy with my conversion, and it cools really well. And it's all stock parts.
Picks of radiator, shroud, and fan clutch are in my gallery.
  #3 (permalink)
Old 07-04-2008, 07:13 PM
srercrcr is starting off with a positive reputation.
If the truck came with a/c the super-cooling radiator is quite adequate, but I'm happy for ya.
__________________
Steve Robbins
'83 XLT Super Cab Long Bed 300-6 (20 mpg hwy) 4OD 3.08, one-owner ordered from the Factory in May '83 with a page-full of options, 175000 miles, all stainless exhaust. Take a look.....
http://s45.photobucket.com/albums/f88/srercrcr/Ford%20F150/?action=view&current=FordF15083.jpg
  #4 (permalink)
Old 07-04-2008, 07:47 PM
Temporarily Deactivated
northern 7.3 is starting off with a positive reputation.
dont use the trans cooler in the rad, just a separate cooler. i had the cooler in the rad crack and fill my trans with antifreeze. i got a big cooler now and it runs the trans cool even when towin heavy loads.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
