has anyone ever hit 4000 rpms in our trucks??
on
We don't have a governer but I am sure the PCM limits RPM. that is removed with some chips though. On a stock (especially high mileage truck) damage to the valve train/piston would be a very real possibility. Hypermax and a few others make valve springs and push rods that make it possible for those who venture into that RPM range
the pcm limits fuel to stop rpm increase at 3400 rpm. running a chipped truck and stage 2's as you are could still run past the limiter, i'm not sure about 4k but i would say its possible to go over 3400 on accell. if you were hard on the throttle with the added fuel from 2's you could take the rpm past 3400 even though the pcm cuts it off at that point. but it should be for long as you would lose the power past that point and come back down to the limiter. you can also blow the engine on a stick truck from downgearing too aggressivly. the limiter is only for fuel, not engine rpm itself
i was floored from 0 till i heard what sounded liek wayy too many rpms and looked down as i let off and saw 60 lol i know going a constant 30 i'm at 2k rpms and 45 i'm at 3000 and when i looked down it was definitely close to 4k rpms.... obviously i'm not entirely sure of the exact rpms but it was VERY close if not at 4k rpms.... definitely sounded pretty cool though when it started going past the normal 32-3300rpms i see
exactly, after i finish everything else i wanna do (tranny, turbo, rods, oil system, fuel system, bigger injectors, head studs, traction bars) i'm gonna build up the entire valvetrain and get this thing to be able to hit 4000 rpms everyday without missing a beat... goal after all this: 650hp
I was talking to one of the guys at Swamps Diesel Performance a month or two ago and they said that they were working on a completely new engine management system that would allow the engine to work properly at higher levels than the normal PCM. Obviously a guy would need the mods to go with it though. They don't have it on their website yet but that doesn't really mean too much with them.
id rather have the cr system have more streetable power and efficentcy <-i cant spell this mornin lol
the big mechanical 7.3 is all hp all the time which is fine for the strip but sucks on the road.
di has a set of thoose 1000hp injectors in a customers truck right now with a set of terminator pumps so we shall see whats gonna happen.....
for the common rail setup i would rather get ahold of a 6.4 and mod it out than convert a 7.3 to cr by the time you buy a pump and injectors and someones ecm to control it i bet im half way to findin a 6.4 then make 400+ on a box. 500+ with a box and injectors theres one out there that they have adjusted the emmisions and are makin over 600 they just cant get enough fuel to the motor now
and i don't think terminator pumps can provide enough oil but i guess we'll see...
a 6.4 block alone probably costs about 20 grand haha i think i'd rather buy a 7.3 block and put 15k worth of common rail stuff on it just for the novelty part of it
I think at this point any of the Big oil setups (term, stealth, BTS, Swamps) can supply oil to any injectors being made right now. Include the SHO's and the DI injectors that Jake is talking about. Oil isn't the big issue. speed and fuel capacity are the limiting factors.
