Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #31 (permalink)
Old 07-08-2008, 08:27 PM
FARM69's Avatar
FARM69 is gaining momentum as a positive member of FTE.
Yeah, it was definitely a marine engine.
Anyways, not to hijack the thread.. but I'd love to hear an old stroker that wound up. I'll take our 78' Kenworth up to about 2600 sometimes and it sounds wonderful. Especially with the two jakes when she winds back down during the shift.
Is there any real benefit to running these high rpms?
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / 10 K / 5er
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water Temp]
4" Straight / EBPV Exhaust Brake / 6637 / CCV / 203 Stat / HX50 (19cm) is being mounted!!
Sponsored Links
To remove this ad, register today!
  #32 (permalink)
Old 07-08-2008, 08:33 PM
glasseater is starting off with a positive reputation.
IF you can keep your torque curve nice and flat all the way up there you'll have a huge hp increase, higher top end, bigger rpm range to mess with.... several benefits
__________________
1997 ford f350
dual 5x36" angle cut MBRP stacks
34's at the moment
3" downpipe
tymar intake
gauges
BTS valve body
stage II injectors
intercooler
twildman chip
14.06@93.8
http://s21.photobucket.com/albums/b295/250xRida/truck/
  #33 (permalink)
Old 07-09-2008, 08:36 AM
Neal 97 250's Avatar
Neal 97 250 has a good reputation on FTE.Neal 97 250 has a good reputation on FTE.Neal 97 250 has a good reputation on FTE.
I can hit 3700 RPM pretty easy and I believe 3900 is the max though. I definately loose boost etc immediately when I hit that. I spun mine up pretty hard one time and saw it jump above 4000 for a split second between shifts. I believe our PCM shuts it down around 3700-3900.
If it shuts it down at 3400 like Tim said I must have programming that lets mine go further because I can easily go above 3400. My power really starts kicking in at 2500 and increases drastically up to around 3600. I believe if I put a map regulator on there I could go further. Mine is just a daily driver but a fast one. I don't run her up that much very often though.
I kind of wish I could go above 4000 at times because it has so much acceleration above 3000 RPM it feels like it is just getting started, then when I hit the top end of 3000's it just shuts down.
__________________
97 F250 7.3PSD
X-Cab, SWB, 4X4
5spd, 4.10gears
3.5” DP, 4” Exh.
FPR,BDP 140v IDM,CCV,HPX,6637 mods
Rosewood Stage II's
6 pos. TW chip
Modded H2E
Valair full feramic clutch
6.oh Cooler
Neal's Pics
H2E install
  #34 (permalink)
Old 07-09-2008, 06:03 PM
FARM69's Avatar
I hear ya Neal, with my stroker it really comes alive 2700+.
I know this isn't a powerstroke, but I used to work for a guy that had a MF 2805 with a V8 in it. You had no power below 2500, but man she would scream from 2500-3600. I'm sure it's the same way with our strokers?
__________________
  #35 (permalink)
Old 07-09-2008, 06:46 PM
73strokin is starting off with a positive reputation.
Quote:
Originally Posted by glasseater View Post
there's been lots of talk about different types of setups for our 7.3s... stealth oil systems is making a new oil system to allow our 7.3s to finally have the oil capacity with the HEUI system to use injectors that can theoretically make over 1000hp.... also there is a commonrail 7.3 system in the works for 2-3 years now.... mechanical 7.3s.... lots of stuff haha
Who's making the common rail system and what do you all know about it? Cost, hp numbers, availability?
Mechanical 7.3s ... P-pump your Powerstroke
__________________
1996 F250 XLT Reg Cab 4x4 Powerstroke, 4.10s, 110k miles
TS Performance 6 Pos Chip, MBRP 4" Exhaust, DIY Intake with AFE Filter, 203* Thermostat, 4" Superlift, Dana 60, 315/70R17s, '08 Diff Cover
Coming Soon!
DieselSite Electric Fuel System, Custom 304 Stainless 4" Dual Exhaust, HPX Line
  #36 (permalink)
Old 07-09-2008, 06:54 PM
FARM69's Avatar
Nobody is making the common rail setup. They are being fabbed up by people.
As far as cost.. I'd look around 15,000-20,000 by the time it's said and done. Not to mention the hours upon hours to get the timing down.
It's been discussed before about getting a pump from a v8 MACK and fabbing up a system.
__________________
  #37 (permalink)
Old 07-09-2008, 07:14 PM
you might not want to say that just yet
__________________
1997 ford f350
34's at the moment
3" downpipe
tymar intake
gauges
BTS valve body
stage II injectors
intercooler
twildman chip
14.06@93.8
  #38 (permalink)
Old 07-09-2008, 07:15 PM
the common rail system, i hear the programming alone is about 3k, the system itself... well over 10k... claimed over 1000hp easily with the setup, and availability is limited, but if you got the money you will be able to get it.... and as to WHO, i've never been told a name, but heard from a reliable source that it's a big name in the powerstroke world
__________________
1997 ford f350
34's at the moment
3" downpipe
tymar intake
gauges
BTS valve body
stage II injectors
intercooler
twildman chip
14.06@93.8
  #39 (permalink)
FARM69's Avatar
I know glass.. I know someone talked about making a kit. Can't remember who though. Thought it was the Double Overtime people.
If anybody does.. its not gonna be cheap.
__________________
  #40 (permalink)
Old 07-09-2008, 07:20 PM
yeah but it sure would be cool to just have that option haha even if i'll know never be able to afford it
__________________
1997 ford f350
34's at the moment
3" downpipe
tymar intake
gauges
BTS valve body
stage II injectors
intercooler
twildman chip
14.06@93.8
  #41 (permalink)
Old 07-13-2008, 02:53 PM
lukecline is starting off with a positive reputation.
Quote:
Originally Posted by secondarychaos View Post
Oh, is that all?
I dont think temps would be that big of a problem. you'd be spinning it so fast that you'd get less fuel and more air. (I would think)
Luke- 4500??? holy crap! where does the pcm start limiting pulse width? does a chip change that?
I cant remember when it starts dropping pw at, maybe 3200 3300 rpms. A chip will not help that, it is a hardware problem.
__________________
99 cc f250 4x4-wildman tuning, wop twins, di ic, richter trans, casserly fuel
96 cc f250 4x4 -38r turbo, stage 1's, TW tuning, elec fuel system, stage 1 trans, intercooler- formerly 12.52 @ 110 mph
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
