has anyone ever hit 4000 rpms in our trucks??
ya can get a brand new 6.4 from ih for 25k just add fluids and power
i ran across one a oil field company had that was wrecked a standard cab single wheel 2wd that they wanted 15k for i almost bought it
although if this new 6.7 comes out in a couple years a bunch of surplus 6.4's may show up.....
the cost of cg has come way down since its gonna be a superior process and it takes less energy to make and less time sitting to make it ready to use
to answer the original question, i've downshifted into 2nd too early and hit 3600. that thing sounded like it was going to fly apart.
4K? I would think you'd have damage...
What's the point of going to 4K? I thought the injectors couldnt get oil fast enough to make that work right? Ex: incomplete fueling...
Maybe you could just get bigger solenoids?
the only thing to get our trucks to consistently be able to run 4000rpm (injector firing wise) i think would be a new oil system
I dont think temps would be that big of a problem. you'd be spinning it so fast that you'd get less fuel and more air. (I would think)
Luke- 4500??? holy crap! where does the pcm start limiting pulse width? does a chip change that?
#29
#30
i would have to believe that is in a marine application.... i've definitely heard of issues with about 3600 rpms
