Where do I add freon? - Ford Truck Enthusiasts Forums
Old 09-26-2002, 08:55 PM
Jim_Banville Jim_Banville is offline
Jim_Banville is starting off with a positive reputation.
I have a small can of R-12 and hook-up hose. Where do I attach the hose on my '89 F-150 w/ 5.8L V8? I had an A/C guy stop by my house and look at the truck. He thought it just needed a re-charge. I think I remember him saying the low-pressure service port where I attach the hose from the freon can is on the right side of the engine (high-pressure being on the left) Correct? Also, the plastic cap on the port on the right has split and fallen off. Is it important to have a cap there to prevent leakage? Or is it just to keep out debris? Where can I find a replacement? It's bigger than a tire valve stem cap. Can I just wrap black electrical tape around it for now?
thanks
Jim
Old 09-27-2002, 11:38 PM
aikigod's Avatar
aikigod aikigod is offline
aikigod is starting off with a positive reputation.
The low side port should be on the passenger's side of the engine, sticking out of the large cannister-looking thing (at least it is on my '92). For best results, you should be using a manifold gauge to add refrigerant to your system; however, if you don't, make sure you add small amounts at a time and let the unit pull down, checking the performance of your system (ie: vent temp). As for the service cap, it's for both keeping debris out and preventing leaks through the schrader valve, but as long as it is not leaking out at the moment, it should be fine (off cycle pressures can be around the 100psi+ range; wrapping electrical tape around it will have NO effect). You can check to see if it is leaking by applying some soap & water solution to the schrader valve and see if it bubbles (PLEASE make sure you either do this after adding your refrigerant or completely dry the water off the valve; trust me, you don't want water inside your system!). Then later on you can scrounge around the bone yards to scarf a cap (just make sure it's from a R-12 system; the newer 134a units have different sized service ports).
Hope this helped a bit...
Old 09-28-2002, 11:01 AM
Thanks for the info! Do you know of any sites that have DIY info for servicing (adding freon & checking pressure) the AC?
thanks!
Jim
Old 09-28-2002, 11:23 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
http://www.ackits.com/forum/index.cfm
http://www.aircondition.com/ straight to the board link
tom
Old 09-30-2002, 07:38 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
95 aerostar 3.0 vacuum housing and diagram jim33067 Aerostar 5 01-21-2014 08:51 PM
AC freon question Little General 1999 to 2016 Super Duty 14 01-03-2013 02:27 PM
Recharge A/c pitmanr2003 Expedition & Navigator 8 05-12-2009 06:08 PM
C4 Line Pressure ? cujo8 Clutch, Transmission, Differential, Axle & Transfer Case 3 07-28-2006 09:52 PM
98 Expedition AC Freon Check njxlt Expedition & Navigator 2 06-13-2003 10:41 AM
Tags
150, 2006, ac, add, adding, board, f150, ford, freon, httpwwwairconditioncom, link, refrigerant, reload, straight, suburban, truck, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
