Refrigerant Capacity
Old 08-08-2002, 12:00 PM
1970xlt's Avatar
1970xlt
1970xlt is offline
Does anyone know the refrigerant capacity for a 1970 Ford F-100 AC?
I have the deeper underdash unit with controls in the dash. I think this is the factory installed unit.
Old 09-25-2002, 09:31 PM
mikester's Avatar
mikester
mikester is offline
You hava a "hang on" kit, there is no spec for the charge on this as the hose lenth can vary a lot, it sounds like a wise *** answer but fill it until it's full, a set of AC guages and feeling the lines for temp will tell a AC tech when it's full.
Old 09-26-2002, 10:33 PM
nitro94's Avatar
nitro94
nitro94 is offline
There should be a site glass on this system to allow you tell when the wystem is full. Add until the bubbles are gone.
Old 09-27-2002, 11:25 AM
1970xlt's Avatar
1970xlt
1970xlt is offline
Thank you for your responses. I have since been told on another air conditioner web site that the capacity is around 36 oz and this is a factory installed unit; Also charge until the bubbles disappear in the site glass. I replaced my damaged hose and installed a new receiver/dryer. I then evacuated the system, while charging I watched the site glass until the bubbles disappeared. The AC seems to be workng fine.
Old 09-28-2002, 10:23 AM
tomw's Avatar
tomw
tomw is offline
reddawgg
1999 to 2016 Super Duty
24
07-19-2022 09:44 PM
poysippiauto
08-04-2017 02:23 PM
oooowoooo
1978 - 1996 Big Bronco
09-29-2016 08:05 PM
makthenif
1997 - 2003 F150
09-05-2016 11:01 AM
tfmech
19
08-23-2011 12:52 AM
Quick Reply: Refrigerant Capacity
