Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #61 (permalink)
Old 07-10-2008, 09:55 AM
headleyj headleyj is offline
headleyj is starting off with a positive reputation.
could I also get a copy of these spreadsheets? headleyj18 @ yah00 . com
  #62 (permalink)
Old 07-10-2008, 11:16 AM
Sarge261's Avatar
Sarge261 Sarge261 is offline
Sarge261 has a good reputation on FTE. Sarge261 has a good reputation on FTE.
Headlyj,
Sent them your way...happy reading.
Sarge
__________________
2006 F-350 PSD Lariat Crew FX4 ALL BLACK
Banks Techni Cooler
Banks Big Mouth Intake Pipe
Banks High Ram Intake
Banks Monster Exhaust Turbo Back
BD Diesel Exhaust Brake
BD Diesel Torque Converter Pressure Controller
Air Ride Air Bags
Deep Sump Trans and Rear Diff. Pans
No-Shrink Tonneau Cover
DiPricol Optix Gauges in A-Pillar
SCT X3 with Custom Tunes From Innovative & Spartan
Kenwood DNX5120
More To Come....
  #63 (permalink)
Old 07-10-2008, 12:00 PM
Sarg - are ya sure you sent it to the right address? sometimes people forget the "E" before the "y"....if it still doesn't work you can try josh.headley@bsci.com
  #64 (permalink)
Old 07-10-2008, 12:01 PM
Sarge - don't see them man...checked my SPAM folder too - some forget the "E" before the "Y"....if it still doesn't work you can try josh.headley@bsci.com
  #65 (permalink)
Old 07-10-2008, 12:05 PM
Sarge - waited a bit and didn't see them come through...some people forget teh "E" before the "Y" in the headleyj18 part of teh email. If it still doesn't work you can try josh . headley @ bsci . com (just remove all the spaces obviously)
Thanks!!!
  #66 (permalink)
Old 07-10-2008, 12:28 PM
mxer0022's Avatar
mxer0022 mxer0022 is offline
mxer0022 is gaining momentum as a positive member of FTE. mxer0022 is gaining momentum as a positive member of FTE.
headleyj,
you got em bud.
__________________
"Ford, Because Driving A Chevy Will Give You Herpes"
2006 F-250 6.0L powerstroke cc 4X4 amarillo special edition
MBRP 4" T-409 turbo back w/cat delete
autometer Phantom II Pyro, 0-60 boost and tranny temp gauges
SCT Xcal3 w/custom tunes
  #67 (permalink)
Old 07-10-2008, 01:16 PM
Sarge261's Avatar
Thanks MXER22,
I am burried at the shop and havent had time to get back. Your the man.
Sarge
__________________
Banks Techni Cooler
Air Ride Air Bags
Kenwood DNX5120
More To Come....
  #68 (permalink)
Old 07-10-2008, 02:01 PM
got em fellas - thanks a ton! you guys are ON IT!
  #69 (permalink)
Old 07-10-2008, 05:36 PM
nico963's Avatar
nico963 nico963 is offline
nico963 is starting off with a positive reputation.
I'd like a copy please.....nahallac1@comcast.net
__________________
2007 cc sb F-250 6.0 4x4 Black Sport FX4
20in Diamo 17's wrapped with Nitto Terra Grapplers(305/55/20)
No Mods
2004 cc sb F-250 6.0 4x4 Black Sport FX4
5in Bullydog exhaust with 6in tip
AEM cold air intake
Traded for 07 with No Problems
  #70 (permalink)
Old 07-10-2008, 11:48 PM
mxer0022's Avatar
Quote:
you got 'em.
__________________
  #71 (permalink)
Old 07-12-2008, 12:33 AM
psdendurance psdendurance is offline
psdendurance is starting off with a positive reputation.
Thread is getting long - but I wanted to thank Sarge261 for the technical spreadsheets. Will take days to read it all and do the research as needed.
__________________
2005 RED F350 6.0 C&C, 6spd,4x4,SC,4:10LS, DRW, Alum Flat bed, Trailer Brake Control, Prodigy Brake control-backup, Post turbo Temp ISSPRO, IEQUUS Water Temp,Oil Press Gauges, Dieselsite water filter, DS-DAHL Fuel Filter, Straight piped, Up-pipe EGR fix, EGRv dummy spool,CCV re-route, SCT 5Startuning STK+20, 40 tow, 60 tow Del 5/19, Build 2/28/05,
  #72 (permalink)
Old 07-12-2008, 01:25 AM
bismic's Avatar
bismic bismic is online now
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
Quote:
Not that I'm sensitive, but don't forget the author of the technical spreadsheets!!!!!!!!!!!!!
While I am at it, let me throw a couple more hints to the new owners / new Forum members.
Not only does the Forum need your active participation (which really should include becoming a supporter) BUT - it is very much appreciated to:
1. Always post a conclusion to your post
2. Thank those that helped you (as psdendurance did)
3. Learn how to give reputation points:
(after a few posts, can't recall how many, you click on the scales in the upper right hand corner of the person's post that you appreciate and a "drop down menu" appears. Make sure you check the "positive" response and then add a short comment. This will add reputation points.)
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
  #73 (permalink)
Old 07-12-2008, 01:53 AM
BISMIC - ops my bad - I knew that - very sorry - great job - to have this information in one place is priceless.
TADA - I did it, now a SUPPORTER. Been on other sites - this one has taught me more.
I thank you and I hope my truck does. At least it runs better
__________________
  #74 (permalink)
Old 07-12-2008, 09:27 AM
philipsc1's Avatar
philipsc1 philipsc1 is offline
philipsc1 is starting off with a positive reputation.
I'm buying a 2003 F350 6.0 L dually and would like a copy of the spread sheets please. The info everyone passes on is priceless! Thanks so much in advance!
Phil
Email philipsc1@yahoo.com
  #75 (permalink)
Old 07-12-2008, 09:29 AM
philipsc1's Avatar
Phil
Tags
03 , 60 , 60l , anthony , branch , dunivan , fitting , ford , hpop , owner , powerstroke , roadking99sbcglobalnet , stc , support , tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
