Bismic, thanks for all your contributions. Could you please e-mail me your spread sheets @ holdendaniels@verizon.net. My truck 6.0L is puking coolant and I keep the degas bottle below the min. line. The dealer quoted me $4000 to fix the EGR oil and coolant coolers. I would like to first diagnose the problem. Truck runs great besides that.
Thanks.
One way to check to see if you have an EGR cooler leak:
Pull the egr valve and jack the back of the truck up 2+ feet. Then pressurize the coolant system to see if any leaks are found in the intake. Look at the down pipe if you have a flange there maybe white crusties there. Pull the egr cooler, block off both ends and pressure test it. Make sure the degas bottle cap isnt bad or the degas bottle itself doesn't have any burrs on the sealing ring. You can road test it with the coolant pressure tester on it to see how many puonds of pressure the coolant system produces. Was the coolant at the min line?. You need to find the split in temps between coolant and oil to check for a restricted oil cooler.
You will see white smoke (coolant) out the tailpipe w/ an EGR cooler leak.
__________________ Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
