Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-05-2008, 01:18 AM
dcaddi2's Avatar
dcaddi2 dcaddi2 is offline
2003 Ford F-250
dcaddi2 is gaining momentum as a positive member of FTE. dcaddi2 is gaining momentum as a positive member of FTE.
Could you please send them to me too? My email: dcaddi2@hotmail.com
Thank you!
  #17 (permalink)
Old 07-05-2008, 02:02 AM
bismic's Avatar
bismic bismic is offline
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
Hey all - save me a step or two ...........
Click on my name and the option should come up to send me an email. Then send me your email address. Let me know if this does not work.
Also -
Here is an index to the spreadsheets (NOTE - these are not active links - intended to ONLY be a list):
General maintenance and troubleshooting topics:
Intro Post
Prevent_ Resolve problems
Normal Readings
Miscellaneous
PCM Re-learn
Injectors
Stiction
Alternator, Serpentine Belt
Glow Plugs
Warranty Work
Transmission
Tranny & Diff fluid change
Differential & rear axle seals
Clunks
Lube points
Turbo repair
VGT Turbo explanation
How to buy used
Cummins Conversion
List of Oils
Oil Leaks
HPOP, STC, Branch Tube
Fuel, Fuel Pressure, and Fuel Pump
EGR, Turbo sticking, coking
Overheating or Puking
Runs Rough,white smoke,no power
Bucking,vibration, shimmy, hop
Turbo flutter, pop,fart
Moan, Droan, noise
Fuses - problems
4WD
Harness and wire chafing
Flush Coolant System
Torque Specs
Break-In Advice
Brakes
Air Conditioner
Heads
Towing
TSB''s
Dash, Stereo
Acronyms
Keyless Entry Code
Suspension (ball joints, etc)
Mods spreadsheet: (next post)
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; Valvoline Premium Blue Extreme 5W40; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; DashDaq on deck; Line-X, CPOhighway Products tool box, tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox
  #18 (permalink)
Old 07-05-2008, 02:37 AM
klmracing klmracing is offline
klmracing is starting off with a positive reputation.
i could not send you an e-mail like that, but i would love to get the spreadsheet from you also. klm_racing@yahoo.com
thanks alot.
  #19 (permalink)
Old 07-05-2008, 02:42 AM
bismic's Avatar
1/2 .....Index for "Mods" spreadsheet (again, list ONLY - no active links):
There are MANY reasons to modify the Ford 6.0L SUPERDUTY. In MANY cases, there is much to be gained from the mods. The 6.0L truck can gain significant RELIABILITY from a large number of mods. LARGE performance gains can be achieved from this engine and drive train. Some fuel economy improvements are possible although they may be slight and often are negated by the "excitement" from the performance mods. Lastly, there are many things that can be done to customize and enhance the looks and the convenience of these vehicles.
Example of "modded" truck
Pull the cab
Miscellaneous information:
Place to buy specialty bolts:
Reliability:
Gauges
Coolant filter
CCV Reroute
ITP return regulated fuel system
Fuel Pressure Mods
Fluidampnr
Dual Steering Stabilizers (Death Wobble)
Tuner reliability with custom tunes - improves shifting, can minimize cylinder pressure
Tuners - Unreliable
Headstuds w/ stock gasket. Good to 400 rwhp - Custom gaskets if pushing over 400hp
Oil Cooler - change it out if you have the cab off or the engine out (they are known to fail unexpectedly)
HPOP and Bracket
EGR and EGR cooler delete
Exhausts - may or may not help performance. Can help lower EGT's
Miscellaneous - Reliability:
High Idle Mod
Block Heater Cord install - in climates that get below 10 degrees F
Oil pan heater install - in climates that get below 0 degrees F
Oil bypass filter
- FS-2500
- Oil Guard
Upgraded Intercooler boot (no more oil problems and no more blowing off due to high boost)
Transmission Full Flow Filter
PowerSteering Filter
Add-on Transmission cooler
Performance
Headstuds - Performance, wire ring gaskets to 500 rwhp, fire ring gaskets over 500 rwhp
Tuner - Performance
FASS or Air Dog fuel system (install after ITP RR fuel system)
Injector upgrades (Beans Stage 1 or higher)
Turbo upgrade or dual turbo's
Torque Converter and Tranny
Air Intake
Cummins Engine
Re-Gearing the Rear End
Miscellaneous - Performance:
Replacement brake rotors and pads
Intake Elbow
Porting, polishing, balancing, blueprinting
New front hubs and lockers
Steering Stabilizer
New / larger turbo OR compond turbos
New / intercooler
Up-pipe
Propane Injection
Exhaust Brake mod
Brake Rotors and Pads
Water / methanol Injection
FICM reprogram
Ported and polished heads
Cryogenic cooling elements and CO2 spray to Intake
MPG - Fuel Economy
SCT Xcal 2 or 3 Tuner - General Economy Tune (w/ EGR functioning) - 1MPG
Synthetic Oil - 5W40: flowability at startup, low ash, high temp stability - MAYBE 0.5 mpg
Fuel Additives - MAYBE 0.5 mpg
Ford TSB on bad mileage
Brainstorm ideas
__________________
Mark
  #20 (permalink)
Old 07-05-2008, 02:43 AM
bismic's Avatar
2/2 .....Index for "Mods" spreadsheet (again, list ONLY - no active links):
Looks and Convenience
Misc Suspension, steering
Lift & Lower kits & Custom wheels
Looks and Convenience - Miscellaneous:
Exhaust kits
2008 mirrors
cBetr Mirrors
2008 tailgate
Security
Fumoto Valve
Improved Fuel Filter (HFCM) drain plug
Door chime eliminator
Block Heater Cord
Upfitter switches
Zoodad
Block Heater Cord
Bilstein shocks
Moog or Beck Arnley Greasable Ball Joints
Power Steering Pump (AGR or Saginaw)
Alternator
Alternator changeout, serpentine belt replacement
Dual alternator or larger alternator (200 amp)
Larger transmission pan
Larger Rear Differential Pan
Larger Front Differential Pan
Harpoon your fuel tank
Engine Idle control
Always bright overhead display
Seat belt alarm disable
Manual Transmission - short throw shifter
Fuel additive bottles
24 inch wiper blades - Really nice!
2007 grill for earlier models
Turbo CoolDown Timer
Batteries
New boots, CAC tubes
Larger fuel tanks / Auxilliary tanks
New lights (headlights, fog lights, etc)
HID Light Wiring Harness Upgrade
Bumpers
BriteBox
Cervini vents (fender vents like the 2008 diesels - OR - vents for the F150)
New Dash
Radar Detector in a gauge pod
Billet Badges
White Knight Back-Up Lights
Battery Trickle Chargers
IPOD accessory to Factory Stereo
PTO
Air horns
Put mirror heaters on an upfitter switch
CB antenna
Disable AutoLock feature (does not lock automatically when truck is started and after all doors are closed.
Four Wheeling - Off Roading
Tires and Wheels
BioDiesel, WVO ??
UOA
Misc Posts
__________________
Mark
  #21 (permalink)
Old 07-05-2008, 03:35 AM
mxer0022's Avatar
mxer0022 mxer0022 is offline
mxer0022 is gaining momentum as a positive member of FTE. mxer0022 is gaining momentum as a positive member of FTE.
we aren't able to send the spreadsheets by using the emails from this site. there is no way to put attachments on the emails sent from here. you are going to have to PM or email your email addresses to us in order for us to be able to attach them to the emails.
to send a PM click on our names and that will take you to our profile. next find the link that says "send private message" or "send email" then give us your email address and you will get them.
__________________
"Ford, Because Driving A Chevy Will Give You Herpes"
2006 F-250 6.0L powerstroke cc 4X4 amarillo special edition
MBRP 4" T-409 turbo back w/cat delete
autometer Phantom II Pyro, 0-60 boost and tranny temp gauges
SCT Xcal3 w/custom tunes
  #22 (permalink)
Old 07-05-2008, 05:47 AM
rsmarcil rsmarcil is offline
rsmarcil is starting off with a positive reputation.
All I can say is...WOW!!! That is a lot of good information. Very well done there, bismic Very well organized. Lots of your time putting that together.
I strongly recommend anyone who does not have this, to send your e-mail to bismic or mxer0022 and get these spread sheets. Thanks. rep points for sure.
  #23 (permalink)
Old 07-05-2008, 08:22 AM
dcaddi2's Avatar
2003 Ford F-250
I don't know why - maybe because I'm a new user, but I can't find the send pm option... I'm sad, I'm already excited about the spreadsheets! Sounds exactly what every 6.0 owner need! Great job guys! My email dcaddi2@hotmail.com, I tried, but no luck with pm. If you could send it without that, I'd be really happy!
Thanks
  #24 (permalink)
Old 07-05-2008, 11:40 AM
please e-mail the spreadsheet to me. klm_racing@yahoo.com thanks alot.
  #25 (permalink)
Old 07-05-2008, 11:51 AM
ok i have posted twice in here, y are they being removed?
i would like the spreadsheet and for some reason i cant see any e-mail or other contact info in your profiles. please send to klm_racing@yahoo.com
thank you very much.
  #26 (permalink)
Old 07-05-2008, 01:13 PM
how do i send pm's and e-mails? i would really like that info
  #27 (permalink)
Old 07-05-2008, 01:57 PM
bismic's Avatar
Left click on my name (BISMIC) in the upper left hand corner of my post. A drop down menu will appear. The options should be there to email and/or send a PM. Click on the option and send me your email address.
__________________
Mark
  #28 (permalink)
Old 07-05-2008, 02:08 PM
dcaddi2's Avatar
2003 Ford F-250
Quote:
Hi!
I'm sorry, but in the drop down menu I don't see the send email or pm option. I tried to get in touch with you all day, but I can't figure out how...
  #29 (permalink)
Old 07-05-2008, 02:37 PM
bismic's Avatar
Quote:
Originally Posted by dcaddi2 View Post
Hi!
Sorry about that - maybe you can't send pm's or emails until 20 posts or so.
Regardless I sent you an email w/ my email address.
__________________
Mark
  #30 (permalink)
Old 07-05-2008, 02:56 PM
mxer0022's Avatar
Hi!
i sent you an email as well. so get with either myself or bismic and one of us will hook you up!
__________________
Tags
03 , 60 , 60l , anthony , branch , dunivan , fitting , ford , hpop , owner , powerstroke , roadking99sbcglobalnet , stc , support , tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
