steering column lower bearing
i noticed a noise in the steering column and after checking it i found the lower bearing has a rubber spacer on the outside,which is likely to be from 1972 so it needs to be replaced since it is deformed and came out.also the ring/nut that holds this bearing doesn't look ford factory.if anyone has been trough this parts or has the truck close to take a peek and compare this parts with my pictures i would greatly appreciatte it.thanks!
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=192733&.jpg[/img]
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=192734&.jpg[/img]
__________________
1972 f250 4x4 ,428 cobra jet,np205,np435 4 speed,dana 44/60,35'' bfg m/t.
More info in my Gallery
1997 f350 4x4,7.3 powerstroke,5 speed,south bend con-o,33"bfg m/t.
