Heater control Won't switch from Defrost!!!!!!!!! - Ford Truck Enthusiasts Forums
Old 09-22-2002, 11:00 PM
wildjon300ci wildjon300ci is offline
wildjon300ci is starting off with a positive reputation.
I can't get my truck to switch from defrost. I have no vent and no floor. Which vacuum lines should I check? Does the system operate off engine vacuum? Are there any vacuum pumps that may need replacing? I was in the middle of trying to hook my AC system but I couldn't get any power to the clutch.
PLEASE HELP.....no vent is driving me outta my MIND!
Old 09-26-2002, 09:38 PM
bluesoftail bluesoftail is offline
bluesoftail is starting off with a positive reputation.
The vacuum for the vent control come from the "coffee can", which is located under the hood. If theres a hole in it, and it leaks, this would kkep the vent stuck on defrost, thats its default relaxed position.
You probably don't have power to the AC clutch because it is OUT of refridgerant. Just hook up the hose, and let it take some refridgerant, when it gets enough to satisfy the level switch, it will kick in.
Old 09-30-2002, 04:14 PM
Thanks for your help. Now where would the coffee can be located? What does it look like? Thanks again.
Old 09-30-2002, 07:37 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
The vacuum reservoir can is usually located under the hood,possibly under the driver's side Inner fender at the front below where an aux battery would go.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old 10-01-2002, 08:45 PM
The only thing I can find that even closely represents a vacuum resvoir is a spherical oblest with only one vacuum line running to it. I'm gonna do some more searching tommarow.
Old 10-07-2002, 01:04 PM
parr4 parr4 is offline
parr4 is starting off with a positive reputation.
Post Heater control Won't switch from Defrost!!!!!!!!!
The defrost function is the normal position of the door/flapper inside the plenum when no vacuum is applied to the dual-diaphram vacuum motor. That motor, located under the dash, has two vacuum lines running to it. One line is color-coded red....full vacuum to close off the 'defrost' air plenum and send air to the floor vents. The other line is color-coded yellow....partial vacuum when function control in in 'mixed' position(both defrost and floor). Check for vacuum to that vac motor. The vacuum resevoir is located (in my '81) on the passenger side of the engine compartment and resembles a 1lb coffee can cut in half. It has one vacuum line to it. That line comes from a small distribution manifold located on the fire-wall. Engine manifold vacuum comes into this distribution manifold. Between the distribution-manifold and the resevoir there is a check-valve....from that check-valve the line attaches to the funtion control connection block(the HVAC controls). Check for vacuum at the resevoir and after the check valve. If there is vacuum present, check for vacuum at the dual-diaphram motor. The 'weak' points are the lines, vac motor, check-valve. Unless the vac resevoir has somehow gotten holed, it should be ok.
Old 10-09-2002, 04:12 PM
beartracks's Avatar
beartracks beartracks is online now
beartracks is starting off with a positive reputation.
On my 77 the vacuum reserve is a round ball on the drivers side inner fender. It has one hose from the engine and one to the HVAV control. It has an internal one way valve to hold vacuum when the engine is off. If you have a leak anywhere along the way the heater default to defrost.
Old 10-09-2002, 04:14 PM
beartracks's Avatar
2002 Ford Explorer defrost problem bunruh Explorer, Sport Trac, Mountaineer & Aviator 6 12-22-2016 09:21 PM
Need new hose for HVAC Defrost Mode Actuator? Blockfort Cooling, Heating, Ventilation & A/C 8 08-26-2016 03:56 PM
Vacuum line to heat/AC unit johnr9q 1968-2013 Full Size Vans 35 06-10-2015 02:32 PM
AC doesn't work on MAX!!! John7894 1987 - 1996 F150 & Larger F-Series Trucks 9 07-29-2002 10:55 PM
A/C Controls vacuum system JBronco 1978 - 1996 Big Bronco 3 11-16-2001 07:23 PM
Tags
bronco, check, defrost, f150, ford, heater, heaterdefrostvent, selector, stuck, switch, truck, vacuum, valve, vent, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
