Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-03-2008, 09:08 PM
buckskinfordgirl is starting off with a positive reputation.
96' F 150 throwing codes, don't know what to do.
My 96' 150 4x4 auto 5.8 is throwing codes PO1351 and PO1359. I took it to the ford dealership and all they said was the plugs were bad. Well, I had already put new ones in a little over a year ago but I went ahead and put some new Motorcraft plugs in. I have put a new cap, rotor, and wires also. They say the diagnostic machine had trouble communicating with the pcm but they don't think it is bad. I have also replaced the ignition module. Would this be the pcm? Also, my 4 wheel drive won't go into low range. It is push button. Any ideas anyone? Thanks!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-03-2008, 11:09 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Did you have these codes before you changed the ignition module?
Both are related to the ignition system and communication between the module and computer, if you installed a black module when you should have a grey one(or vise versa) you'll have problems since some of the signals are on different pins.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #3 (permalink)
Old 07-06-2008, 07:26 PM
If I remember right I did have these codes before this was replaced. I have had so much trouble it is had for me to remember what I haven't had wrong with this truck. Anyone have any ideas on what else to replace? haha...
  #4 (permalink)
Old 07-07-2008, 03:14 PM
alxsnmr is starting off with a positive reputation.
I would check the wiring to the TIF which should be on the driver's side fender between both the distributor and the computer. Look for frayed, chaffed, or other wise abused wiring looms and wires to see if you have some connection problems. Like Conanski has stated, you have a signal issue either the module is the problem or you have frayed wiring that needs repaired. Any corrosion in the wires can cause a loss of voltage, i.e. signal, and lead the computer to believe a problem exists. If you remember replacing the module where did you get it?
After thinking about this, did you remove the PIP? If this is missing the distributor will not get the spark advance and retard signals during use of the engine.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, otherwise still stock.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
