Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-03-2008, 08:55 PM
pipman76 is starting off with a positive reputation.
driver side rear wheel not lined up right
ok guys i have post this before.my drivers rear tire and wheels doesnt sit lined up like it should if i measure the front bottom fender well to the tire treat its about nine inches on a measuring tape go over to the rear passenger side and measure and comes out to be 8 inches,ive measured the center of the leafs too the front of the leaf and both sides come out too be around 21 inches,i dropped the rear today and found that the pin that runs threw the leafs are not broken on either driver or passenger side ,i have replaces axles,drums,back plating even brakes still looks lope sided on the driver side it drives me crazy,,the frame doesnt seem to be warped only thing i know to do is try another rear end and see what happens
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-03-2008, 09:52 PM
81-F-150-Explorer is gaining momentum as a positive member of FTE.81-F-150-Explorer is gaining momentum as a positive member of FTE.
Is the bed of the truck on it even?
  #3 (permalink)
Old 07-03-2008, 10:16 PM
77Explorer is starting off with a positive reputation.
The besides may be on uneven
  #4 (permalink)
Old 07-03-2008, 10:43 PM
welll thats a thought.i have notice since yall mentioned it,that the bed front of the bed on the driver side has a slight wider gap between it and the cab,is it possible the bed has been removed and not bolted on evenly is this possible,my parts truck is a short bed truck also i could lift mine off and set it on one day and seee what happens
  #5 (permalink)
Old 07-04-2008, 12:15 AM
Quote:
I was doing some work on my bed today thats why i mentioned it seems my bedside is about a 1/8-1/4 off from where it needs to be im sure some probly skipped out worse the others when new
  #6 (permalink)
Old 07-04-2008, 12:21 AM
daddy172005's Avatar
daddy172005 is starting off with a positive reputation.
I didn't see where you had changed the shocks. Maybe one of your shocks in a bad enough shape to cause the difference in measurement
__________________
Mason
74 F100 302
  #7 (permalink)
Old 07-04-2008, 01:35 AM
yea thats a good point i havent thought about the shocks
  #8 (permalink)
Old 07-04-2008, 01:37 AM
i will change the shock and post the results
  #9 (permalink)
Old 07-04-2008, 01:55 AM
wdfp is starting off with a positive reputation.
Measure your bed diagonally, front left to right rear and right front to leaft rear, measure from outside corner on the stake pocket or just the same place on both sides, this will tell you if it is square or not, it probably is but running out of things to check. they should measure exactly the same.. maybe one wheelwell is in the wrong place too,
  #10 (permalink)
Old 07-04-2008, 02:55 AM
It's possible the truck bed has been put on uneven, or that the box isn't "square".
Especially since you mention a simular gap between the bed and cab.
  #11 (permalink)
Old 07-04-2008, 10:14 AM
wdfp... i just measured the bed corners,i measured from drivers frontstake hole too back passenger side and that came out to be 98 1/2 inches
the passenger front to driver rear was 98 inches a 1/2 inch difference do u think this could be my problem
as i was sitting on the grond looking i notice another way to describe this to ya the wheel-tire ,imagine how ur front driver wheels looks as if u was turning left slight thats kinda how the rear looks,if u were to first look u would say its a warped rim but ive even rotated wheels-tires same thing
  #12 (permalink)
Old 07-04-2008, 10:53 AM
i just did some frame measuring, i took a tape and measured the frame in front of the tire and and back side as well and from the frame to the center of the tire
front-15 1/2 inches
rear14 1/2
passenger side i did the same thing
front and back of tire and frame was 14 1/2 inches
as u can see the front side of my tire is turning out slightly
i havnet ried the shock replacement yet but do u guys really think a bad shock would make it look this way????
  #13 (permalink)
Old 07-04-2008, 11:02 AM
F250army45d is starting off with a positive reputation.
Do the tires wear even if so it is probably just a body alignment thing. I would think if the rear tires wear evenly there is no issues with the axle being out of wack changing shocks is still probably a good idea but as I stated if the tires wear the same look to the body. Also does it seem to drag or pull any? If so then I could be wrong and some thing in the alignment of the wheels could be off. Also bad rear bearings can cause uneven tire wear.
__________________
mikes 77 F250 4x4 highboy
  #14 (permalink)
Old 07-05-2008, 01:37 AM
when i get time im gonna remove the bed and do some more ispections and measuringments then il set the bed off my parts truck onto my 74 and see if that makes a difference if that doesnt work ill remove the whole rear and leafs from my parts truck and install and see what that does after all that and no change i guess ill pull alll my hair out,cause when u set back and star eat the truck from the passenger side u looks really good and moving over too the driver sidelook awful,i plan on making this a show truck plus weekend cruiser but if i cant figure this out i will be selling it i dont really wanna do that
  #15 (permalink)
Old 07-05-2008, 01:40 AM
i havnent driven this truck much ,ive only own it for as few months now,and the tires and wheels havent been on that long so i dont know if ive driven it enought too tell about tire wear
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
