Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 07-05-2008, 03:57 PM
F250army45d is starting off with a positive reputation.
As to tire wear I wiould have to guess around a hundred miles you would see it but that can also depend on how bad out of wack some thing is could take less could take more.
__________________
mikes 77 F250 4x4 highboy
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 07-05-2008, 05:11 PM
pipman76 is starting off with a positive reputation.
could my axle housing be bent or warped a slight bit
  #18 (permalink)
Old 07-05-2008, 05:31 PM
that could be man try to measure between the rims not the tires pick a spot on the rims and measure from left to right and then repeat on the back side make sure your using the same spot for front measurement and rear measurement so you don't get thrown off by the rims. You may employ the help of a four wheel alignment shop with a lazer set up so they can measure it.
__________________
  #19 (permalink)
Old 07-05-2008, 07:06 PM
81-F-150-Explorer is gaining momentum as a positive member of FTE.81-F-150-Explorer is gaining momentum as a positive member of FTE.
I second the Four Wheel Alighnment.
Does the truck seem to go sideways down the road? Have a friend drive behind your truck on a straight stretch of road and look etc..
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
