my truck runs smooth from 0-50 mph but at 55mph it feels like a tire has a bad belt or unbalanced but soon as i reach 60mph it start to smooth out again should i have my tires checked out???
We hit just about 55 and the steering starts to shudder and shake a bit. LOL. I'm planning on pulling the front tires and running 'em down to FireStone and asking for a balance check.
Yeah know? One thing to check would be rocks/dirt/mud that builds up inside the wheel rims. It wouldn't take much to throw it out of whack. One van I used to drive got stuck in the muddy sinkhole we call a parking lot. Right up to the door jambs. Had the local shop use a power washer to get all the rocks/dirt/mud out...it couldn't go faster then 45 without feeling like it was going to shake apart.
S-
__________________
The old girl is as follows:
1975 Ford F250 Camper Special
Normal Cab.
Rear Wheel Drive.
360 CID.
Auto Transmission-C6
Last of the vin: W69956
mines is a shortbed 2wd it doesnt see any mud but i will check tommorrow for rocks in the tread,no listen to this!!!! last week i had a new roof installed on my house tuesday on my way to work i was late because i had a flat tire andfounr a roofing nail .could my truck possibly have pick one up ??...now do u think that could cause a vibe going down the road
Bad tire balance will be felt mostly in the steering wheel unless it is way out then everything will shake. Often rotating the tires front to rear will fix the problem.
Get in the habit of "inspecting" your tires EVERY TIME you walk up to, away from (if you can) or by your vehicle. I've spotted a few nails that way, so the flat fix is in the drive & not on the highway.
Check the tires for condition, flat spots--lock 'em up lately?
Check rims for dings, inside, out.
Check driveshaft for bends, dents.
When you take for balance, have them check the wheels for true (or you do do it, just jack it up and spin using something fixed to the vehicle to look for rim wobble) and run out. Think the factory gives a rip about true wheels? Not as much as you.
