Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-03-2008, 08:41 PM
powerstroker27 is starting off with a positive reputation.
Exclamation Help!!! Gauge install gone wrong
I have no power anywhere, ie lights wont turn on, gauge cluster doesn't light up, nothing works. Before u ask yes i did disconnect the batteries before i started and yes i did reconnect them when i tried to turn things on. is there a fuse or a relay that i can check/replace....or did i fry something much more important.....?
__________________
2004 F350 4x4 auto c/c lb: afe intake, 5in straght pipe, custom sct by SDT, power elbow, 6in lift, lin-x'd two tone line, 37x13.5x18's mud grapplers
2001 f250 4x4 6sd s/c Lb: 6637, zoodad, 5in straight pipe, overboost, dp-tuner
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-03-2008, 08:44 PM
messeswithtrux is starting off with a positive reputation.
what did you tap for power? did you use a check light? for switch power or constant? you may have tapped a switch power source which means for your gauges to work, that accesory must be on. make sure you have a power source that uses ignition as your on and off. how about ground?
__________________
2002 CC LB lariat F250
MODS - AFE stage 2 intake, MBRP 4 inch cool duals w/ 5 inch tips,john wood valve body,DP tuner (NS, stock, 60 tow, 80 eco, 120 race, 140 smoke), 4 gauge pod w/ AM NV gauges,SS HPX, CCV, foil delete, hutch, harpoon. SITTING IN MY CLOSET.... ATS housing, wicked wheel, blank EBPV and pedestal. just waiting for up-pipes
  #3 (permalink)
Old 07-03-2008, 08:51 PM
zx250's Avatar
Spread the wealth my ass!
zx250 is a name known to allzx250 is a name known to allzx250 is a name known to allzx250 is a name known to allzx250 is a name known to allzx250 is a name known to all
Are you sure you got your batteries hooked up good and tight? Any power to anything?
  #4 (permalink)
Old 07-03-2008, 08:54 PM
i used the plug under the dash with the red wire with yellow trace like every set instruction ive found said to. the gauges worked at first but the egt wasn't responding, it lit up but didn't register temp. So the only wire i found to be completely different between the boost egt gauge was the ignition power source. I disconnected the batteries, and went to change the power source to #29 10amp mini-fuse in the fuse panel. when i reconnected the drivers side battery nothing worked, not the gauges not the gauge cluster, not the lights, nothing. tried reconnecting the other batt and just for a sec the gauges lit up but then went blank and now nothing works.
__________________
  #5 (permalink)
Old 07-03-2008, 09:00 PM
Quote:
just went out side and tightened the cables on the batt, turned the key and the main gauge cluster lit up for a sec then died.......
__________________
  #6 (permalink)
Old 07-03-2008, 09:03 PM
zx250's Avatar
Sounds like you have some dead batteries or a bad connection somewhere. A bad fuse would be bad until you fix it, not come and go. Double check those connections, on both batteries.
  #7 (permalink)
Old 07-03-2008, 09:24 PM
Ok i went out and brushed the terminals till they shined and the truck now starts and everything works........that is except my egt gauge. I can see it flick like its reseting itself when i turn things on but it will stay just below 100 degrees and won't change. so im starting to wonder if i have a bad sender.
__________________
  #8 (permalink)
Old 07-03-2008, 09:27 PM
zx250's Avatar
Could be a bad sender, Make sure the the lead wire coming from the probe is not touching something. Where did you mount the probe? If it is a clamp on type, I think in needs to be grounded.
  #9 (permalink)
Old 07-03-2008, 09:32 PM
its mounted in the manifold but im about to go and make it have its own ground. Right now its t'd in with the boost gauge.
__________________
  #10 (permalink)
Old 07-03-2008, 09:57 PM
ok made a seperate ground wire, checked the grounds to make sure they worked, checked the power to make sure it works, checked to see if there were any kinks in the line, and everything works and seems fine except for my gauge won't read the temp......i even tried moving the sensor in and out of the hole but it had no effect.
Can anyone help me with this?
__________________
  #11 (permalink)
Old 07-03-2008, 11:42 PM
Tenn01PSD350's Avatar
Miller Brewing Co
Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.
What gauges did you get and what is the brand of the pyro sendor?
__________________
2001 350 4X4 AUTO, GTP38R, Swamps Hybrids, DPTuner live tuned, PMRs
399.99/789.54
Mike
  #12 (permalink)
Old 07-04-2008, 01:22 AM
twags6's Avatar
PAA Member #7 and FTE
twags6 is gaining momentum as a positive member of FTE.twags6 is gaining momentum as a positive member of FTE.
Did you use an extension wire to hook the egt sensor to the sending unit? If you do, take the probe out and hook it up directly to the sending unit. You can give it a quick test with a lighter before you put it back in the manifold. The one I got with my gauge was bad (one wire had 2 ohms resistance) and kept the gauge from reading anything.
__________________
Trevor
01 F-350 CC 8ft bed SRW 7.3L a/t.
gotta feed the PMS
133k
PAA Member #7
Carlisle All Truck Nationals
Carlisle All Truck Nationals 2009 FTE registration thread.
  #13 (permalink)
Old 07-04-2008, 08:21 AM
zx250's Avatar
I hate to ask the obvious question, but you are running your truck and allowing enough time for the temps to get up enough to move the gauge?
  #14 (permalink)
Old 07-04-2008, 11:21 AM
Lovin7.3's Avatar
PAA #28
Lovin7.3 is gaining momentum as a positive member of FTE.
Quote:
Hopefully not Glowshift or that would explain everything
__________________
Zach -- PAA #28
Psycho Soot Diesel
Lafayette, Indiana
99.5 F-250 7.3L Auto 5" turbo back, Banks Six Gun, Autometer Boost, Autometer Trans Temp, DP Tuner (no start, stock, 80E, 120race) HPX, WW, non-ebps pedistal, bellows kit, zoodad
  #15 (permalink)
Old 07-04-2008, 01:46 PM
twags6's Avatar
EGT's should move right after startup. My gauge reads about 150-200 within 30 seconds of starting.
__________________
Trevor
gotta feed the PMS
133k
PAA Member #7
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
