2002 v6 po4o1 how to clean egr ports ?
Old 07-03-2008, 06:57 PM
xclint's Avatar
xclint
xclint is offline
p0401 code back on after 8 months - lot of discussion on cleaning TB ports and intake ports. TB was clean but confused on where are the EGR ports located on manifold - do you have to pull it to clean ? Any info or pics would be helpful.
Old 08-07-2008, 11:10 AM
T K's Avatar
T K
T K is offline
What did you do to fix it 8 months ago?
On my snap-on scanner the possible causes strongly looks to the DPFE sensor as the cause. Might want to replace it. I know Ford has up-dated this part because of the problems with the original sensors & there is a TSB out for this issue (TSB 04-11-01). You might want to look into it.
Old 08-07-2008, 01:29 PM
xclint's Avatar
xclint
xclint is offline
Changed out the DPFE ~ Sept 07 with one purchased from Pep Boys - cleared code - lasted about 7 mths.
Read all the info on using only OEM part for this failure
Live in Tx where heat can be an issue under the hood.
Just want to verify that EGR ports are clean - when I cleaned TB didn't notice anything plugged but that was the TB stand alone.
Has about 75K miles on it.
Thanks for responding TK -
mredington
1997 - 2003 F150
12-04-2015 07:23 PM
baymee
47
12-28-2012 05:21 PM
Nitro Blazer
1997-2006 Expedition & Navigator
03-02-2012 05:40 PM
jrdz82
1997 - 2003 F150
11-01-2006 12:22 AM
AggieMike
Modular V8 (4.6L, 5.4L)
05-03-2004 01:40 PM
Quick Reply: 2002 v6 po4o1 how to clean egr ports ?
