oil pressure gauge
hi, thanks for all your advice, i have been busy of late so sorry for the delay.
it was a loaded question due to me having issues with what appeared to be very low pressure at tick-over. since owning the truck i have never used 5-30 oil as recemended until the last oil change. this gave me cause for concern due to lower recorded pressure through out the rev range.
gone back to 10-40 oil and all is well.
i could have lived with the 5-30 if it had not been so low at tick-over (7-10psi) when motor was real hot.
blueovalfitter 10psi per 1000revs sounds good but my motor happly ticks over at 600revs so this leaves tick-over on the low side.? but the good news is that with the ac fixed and turned on it has brought the tick-over up to 750rpm and the oil pressure up also. thanks bokker.
