Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 07-04-2008, 01:21 AM
Tenn01PSD350's Avatar
Miller Brewing Co
Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.
Quote:
Originally Posted by mongo75 View Post
Well as Mike would know, I replaced my shaft about umm, has it been a year and a half already??? Well, there should still be the same two yellow balance / alignment dots on the shafts, that the shop put on them .
Well Danny, if the shop installed the shaft, maybe they ought to pay for it. I just don't remember all the details. If they didn't, and balanced it, then they still ought to pay for it. I know, wishful thinking and more trouble than it is probably worth.
__________________
2001 350 4X4 AUTO, GTP38R, Swamps Hybrids, DPTuner live tuned, PMRs
399.99/789.54
Mike
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 07-04-2008, 01:43 AM
zx250's Avatar
Spread the wealth my ass!
zx250 is a name known to allzx250 is a name known to allzx250 is a name known to allzx250 is a name known to allzx250 is a name known to allzx250 is a name known to all
As much as I hate to say it, I don't see anyway that shaft will still be true. They are not made to bounce and roll. Gotta believe it is warped, bent, dinged or damaged in some way that will cause it to be unbalanced. But, what do I know. I really hope is will be as simple as bolt up and go. Good luck.
  #18 (permalink)
Old 07-04-2008, 02:32 AM
mongo75's Avatar
Marine Lifer
mongo75 has a good reputation on FTE.mongo75 has a good reputation on FTE.
Mike, I installed the shaft myself almost two years ago, but I don't know what caused it to fail. Either way I'm "liable" for any repairs
Barry, I too hope it's just a install and go. I don't want to get this thing retubed for another $300...
__________________
Danny PAA member #12
SoCal Chapter Member
Early 99 F-350 Lariat Dually 4x4 CC LB 7.3L, AFE Stage I, 3 gauge pillar, 4" Magnaflow SS str8-pipe, DP Tuner, Swamps 175/146 SS inj, ITP Ovrbst, CCV mod, SS HPX, Cackle-cure, Foil Del, ZooDad, Air Horns 320hp/704tq
I fight for America so I buy from America- who are you fighting for?
  #19 (permalink)
Old 07-04-2008, 05:56 AM
AustinS is gaining momentum as a positive member of FTE.AustinS is gaining momentum as a positive member of FTE.
Find out who the Dana Spicer distributors are in your area here:
Dana Spicer Parts - Locate Light Duty Parts
They are the only u joints and hardware I buy anymore. The quality of the Chinese parts invasion at the normal parts stores keep getting worse.
Dana Spicer still makes a high quality product that is many times stronger than the rest of the competition. They are pricier, but worth every penny.
Austin
__________________
2001 F250 Lariat SC PSD SWB 4x4
  #20 (permalink)
Old 07-04-2008, 09:37 AM
donewithsparkplugs is starting off with a positive reputation.
Remember when installing your shaft it can be 180* out of time and that will throw it of balance. Your better off to take the front slip yoke off and take it in to be sure its it time and balanced, 180* out could cause more damage.
180 off isnt so bad that just vibrates you want to really do damage put it 90 off that binds
  #21 (permalink)
Old 07-04-2008, 10:57 AM
rebelchevy02 is gaining momentum as a positive member of FTE.rebelchevy02 is gaining momentum as a positive member of FTE.
Austin
I completely agree with this. And everytime Ive taken a driveshaft to get balanced, to a driveshaft shop, they have always commented on "wow you have the nice u joints on here". I always use spiced non greaseables. They are actually what the OEM joints were aswell.
If I want to change the yoke myself it's just a matter of taking off that big a$$ nut on the input shaft, and replacing the seal right?
Technically yes, but its important to make sure you dont over tighten and re adjust the crush collar, which changes your backlash, or under tighten, and well, i think you can tell were that goes.
__________________
Mike AKA "Speedy"
02 F250, ECSB, 4x4, PSD, Auto, 190+k on the ticker
Detroit locker and go fast parts.
  #22 (permalink)
Old 07-04-2008, 11:52 AM
mongo75's Avatar
Marine Lifer
thanks for the advise everyone, but that's just about everything I doing already- I hate foreign stuff hehe, I went the dealership and I know they run Spicer (OEM) only. ANd I don't know if you missed it in an earlier post plugs, but I'm lucky enough to have two dots that are my balance alignment line up points. I'll get the parts in tomorrow, and if I feel any vibration I'll play it safe and take it to a driveline shop.
__________________
  #23 (permalink)
Old 07-04-2008, 07:40 PM
yamaguy's Avatar
"Joker of the year-2007"
yamaguy is gaining momentum as a positive member of FTE.
Quote:
I know on my 03' the spline on the shaft has a flat spot and can only be put back together one way.
__________________
Dale
PAA #47
03 F-350 XLT cc LB 4x4 7.3 psd 286,000 MI 9' 2" BOSS Ploy Vee
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
