1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
07-03-2008, 06:08 PM
Box Builder
tuffer front driveshaft
been watching u-tube what a joy of broken parts.but it seems that the front drive shaft has a way of flying out from under the frame of our trks.just wondering if anyboby has renforced or made tuffer the frontend?
__________________
Brad
PAA MEMBER #71
under certain circumstances,profanity provides a relief denied even to prayer -MARK TWAIN
01 f-250 CC,auto,4x4,4"lift,35's,6637,X-wheel,4"turbo bk.exhaust,H&H fuel mods.gauges,6.0 trans cooler,HPX,cold A/C,18k.zoodad
1965 f-100 2wd,390,4spd,3.50posi,all manual
Sponsored Links
To remove this ad, register today!
07-03-2008, 06:37 PM
I've busted a lot of things but never a front drive shaft. This will keep things from flying. These are on all u-joints.
__________________
Kevin SLEDPULLMOTORSPORTS
SPONSORED By
Air Flow Systems
Terminator Engineering
DI Performance, South Bend Clutch
Discount Power Parts, Grand Rock
07-03-2008, 07:25 PM
Box Builder
Quote:
Originally Posted by
mech2161
If thats your trk. smoken down the track its cool,and I like the pan saver setup,whats the 3/8 studs off the housing for.or is that so you can center it for the you joint? and these guys broke there front shaft in back to back pulls on u-tube.
__________________
Brad
PAA MEMBER #71
07-04-2008, 09:58 AM
The bolts are to center it and also hold it in place so you don't have to weld to the housing. Post a link for the vids of the busted shaft.
__________________
SPONSORED By
Air Flow Systems
07-04-2008, 10:35 AM
Box Builder
mech2161
this is what I found and the side bar there is more to find.
http://www.myspace/gvpsysam
__________________
Brad
PAA MEMBER #71
07-04-2008, 11:00 AM
Box Builder
Ok that link didn't work I'll go find the other one.
__________________
Brad
PAA MEMBER #71
07-04-2008, 11:07 AM
Box Builder
__________________
Brad
PAA MEMBER #71
07-04-2008, 11:49 AM
Nonsupportive
mech2161
Youve broken a rear drive shaft havent you though....
__________________
02 F-350 with lotsa bling, some you see, some you don't.
Licensed 7.3 engine remover/installer
RIP Jet, my friend.. You will be missed!
07-04-2008, 01:46 PM
strokin_it7.3
Yeh I broke it twice.
__________________
SPONSORED By
Air Flow Systems
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
