Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers And 5th Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Towing, Trailers And 5th Wheels SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-03-2008, 04:28 PM
highplanesdrifter is starting off with a positive reputation.
Specs for towing 20,000lb.?
Hi Folks
New poster in these forums ...
Not quite a truck owner yet, but looking actively.
Just bought two farms in Southern Ontario, total 400 acres, about 100 miles east of Toronto ... they are about 5 miles apart ...
Have a 75HP New Holland tractor in a Coverall at one place, need to transport it to the other frequently to build house, driveway, septic bed etc. ...
The tractor weighs about 8-10,000lb., depending on attachments such as loader and backhoe etc. ... I figure another 10,000lb. for a gooseneck flatbed trailer ...
I'm thinking of an F-350 with these specs:
Miles: 80,000-130,000
Eng.: 7.3L Turbo Diesel
Drive: 4X4
Wheels: Dually
Hitch: Flip Ball in the bed
Box: Extended (I'd like to haul stuff, from gravel to wood chips)
Cab: Regular (will NEVER have more than one passenger)
Brakes: Brake Control Package for the load
Is this a good spec.? Will I be able to find something like this? How much should I expect to pay?
Thanks folks!!
HPD
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-04-2008, 01:33 AM
Super Steve is starting off with a positive reputation.
I think you will technically be over the limit if it actually adds to 20k.
I don't think the trailer will weigh that much, but I may be wrong.
But, you will only be going 5 miles, probably slowly on back-country roads at reasonable speeds so it shouldn't be unsafe.
Definitely get the 7.3 versus the 6.0, proven more reliable, torquey, and better mpg.
Definitely get the long bed. Bigger fuel tank and better for goosenecks.
Definitely get the dually since you plan to tow HEAVY.
I would at least get the extra cab so you can recline the seats a little and lock more gear in your truck.
__________________
04 PSD CC 4x4 XLT
8" Superlift, 37"BFG's
  #3 (permalink)
Old 07-04-2008, 08:03 AM
jefftb is starting off with a positive reputation.
Most GN's rated for 14K run between 5,800 and 6,500 lbs. depending on length. You can look at several GN manufacturer websites to check their running weight.
__________________
2003 F350 CC 7.3 LWB 4 x 4
  #4 (permalink)
Old 07-04-2008, 11:12 AM
grafekie is starting off with a positive reputation.
If your trailer is under 25' and is only a four-wheeled trailer you probably will be under 5000lbs, even as a goose. If you bump up to a dually type trailer you may see empty weights up around 8000lbs. For that load you do not need such a heavy trailer and would be fine with a 20k rated two axle, four wheeled trailer. The dually truck will then be completely legal towing the tractor and trailer.
__________________
Nathan
2002 F150 SuperCab Short Bed FX4 5.4L V8 Firestone Load Level Air Suspension
2007 Featherlite 8413 20x7x7' Stock Trailer
  #5 (permalink)
Old 07-04-2008, 12:34 PM
Thanks folks! That's a good start.
Super Steve: Appreciate the rec for at least an extended cab for keeping things safe, and dry. I'd prefer that to an in-bed toolbox.
Jefftb: I'll definitely have to firm up the trailer and tractor gross weights. I'll be happy if it all comes out a bit lower. I have two ways to go between the two farms, one through a substantial creek valley, and one about 4 miles longer, but flat. I'm looking for being legal and being safe.
Grafekie: Thanks. I'll do more inquiring about two axel, single wheeled, with about 20k GVW rating. That seems like a good combo, especially if the truck is dually.
Anyone: If not an F-350, are there Chevy or Dodge equivalents I should also be looking for?
Thanks all
HPD
  #6 (permalink)
Old 07-04-2008, 01:54 PM
jake00's Avatar
FTE is my crack
jake00 is a splendid one to beholdjake00 is a splendid one to beholdjake00 is a splendid one to beholdjake00 is a splendid one to beholdjake00 is a splendid one to beholdjake00 is a splendid one to beholdjake00 is a splendid one to beholdjake00 is a splendid one to behold
lotsa farmers around here farm a few different properties. its not uncommon for them to just run the road. (prob quicker than loading, towing unloading)
__________________
RIP BIG GREEN owned her from 08.17.04 - 05.10.08
  #7 (permalink)
Old 07-04-2008, 02:30 PM
Bigskyduty is starting off with a positive reputation.
Quote:
x2- Thats what my folks have done for years. Unless you have to go a long distance this is the way to go, just watch traffic tho, people can be idiots.
__________________
2008 F350SD CC PSD 4x4 long Bed
  #8 (permalink)
Old 07-04-2008, 02:47 PM
texastech_diesel's Avatar
texastech_diesel is gaining momentum as a positive member of FTE.
Yeah its not uncommon to see some pretty big peices of farm machinery move on the highways out here, especially cotton equipment. They actually drive right down the middle taking up most of both lanes sometimes. 5 miles isn't that far to run, especially if theres a nice wide ditch down either side.
I don't know about Canada, but tractors can use highways in Texas as long as the have headlights, a taillight, reflectors, yellow flashers, and a slow mover sign.
__________________
Bryan
  #9 (permalink)
Old 07-05-2008, 11:31 PM
Difference in Tire Load Capacity?
Deleted. Mis-post-will start separate thread to avoid
__________________
  #10 (permalink)
Old 07-08-2008, 08:15 PM
bigredtruckmi's Avatar
Farmer and proud of it
bigredtruckmi is gaining momentum as a positive member of FTE.bigredtruckmi is gaining momentum as a positive member of FTE.
Here is a site with all vehicle ratings. from trailer life magazine.
Trailer Life Magazine: America's Number One RV Magazine
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #11 (permalink)
Old 07-12-2008, 11:19 PM
F350-6's Avatar
Slow Typing
F350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to behold
I'm kind of late on this thread, but welcome to FTE. I haul a 75 HP New Holland tractor all over the place with my 350 with no issues. I use a 24' gooseneck trailer with 2 7k (lbs) axles under it. The trailer is around 3200# empty. You'll be fine with a F350.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 270,000 & counting. 6637 w/ Pete's armor. Cold air set up for 6637
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
MORE (Military Online RElay)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
