Michelin LTX A/T2
#31
I had the tire shop tell me to rn them for a bit because they are curious about where the tread wear will be and an adjustment will be made if unaccdeptable. My truck is a dually with 235/85/16 tires. My fronts are wearing well. Here is how my rear tire treads are wearing:
Excuse my 'kid art' but if each row of '=' is one of the rows of threads, the '|' is where the thread feels higher (worn less) and the '+' is where its lower (worn more). The tire shop advised that the wear looked to be caused by underinflation and by adding air the '+' area should have more contact pressure with the road and wear better. This made it worse IMHO and the truck road too rough when empty. By lowering the pressure it seems like the two center rows of treads are evening out some. We looked at the tire shop owners truck - a dodge diesel SRW 4x4 and his rears are wearing the same way and his steering are just fine - I think they only rotated tires once on that truck.
#32
#33
My LTX A/T2's were replaced by the tire shop. The owner has Hankook's on his 1 ton Dodge that he tows with often. He has 40K on them and they look great. Mine now have a few hundred and look brand new ()!
No challenges yet from the weather or towing, but I'll post if I have any problems!
Glad I bought these instead of the Michelin tires now.
#34
#35
i ve put about 10k on a set of ltx/2 now on my 05 f350, towing and hauling every
single mile, they still look new and seem to be wearing well, i have only rotated
once, i do have some minor vibes, but its not as bad as any of the 3 sets of contis i went thru b4 these--truck has currently 40k miles
you can search my post in this foum from last yr, i was 1 of the 1st to get these
new tires
new tires
#37
There's a alignment shop here in town that has a pretty good rep and one of the owners told me he thought Michilens were the best tire period and he had LTX M/S tires on all his vehicles, but he would never put them on a SuperDuty. He said he didn't know why, but for some reason Michilen tires don't like a SuperDuty or visa versa. Based on the wear of the tires I had, it looked like an alignment problem, but it was on the rear tires too and the tire shop said the alignment was OK. I'm taking it to the dealer Wednesday and have them do an alignment. Might be a waste of money, but I'm tired of messing with tires.
#38
#40
#42
I know this is an old post but I have just put some 275/70-18 Kumho's on my '06 based on previous use on an F150 and my wife's Escape. So far the ride, wet traction and handling is much superior to the OEM Conti's plus I appear to have picked up about 1+ mpg based on a 1900 mile trip this past week. I do seem to have a bit of front 'shake' when I just start to go into a slight curve, but at 65K+ miles it might be the tie rod ends or other front suspension parts and need to crawl under the truck today to look(and of course fix - and hope it's not ball joints).
#45
Wow, I am impressed with those Michelins. I just had to put new tires on an E-250 work van and we got ~115k out of the original Michelin LTX M/S2 tires. Needless to say we put the same tire back on it. I will be looking very closely when I need to put new tires on the F-250. The selection of 20" tires is not that great.
