Manual Fuel Selector Valve
Last year, I had a problem with my FSV failing on a road trip. I'd like to avoid this.
I'm looking at McMaster Carr for three way ball valves. Ball valves don't fail.
What materials should I avoid for Diesel/BioDiesel?
There are different materials of valve, ball, and seals.
Seals: PTFE, Glass Filled PTFE, Buna-N, Viton
Metal parts: Bronze, Brass, Aluminum, 316 Stainless, Nickel plated, Chrome plated
What will break down in diesel fuel? Some of those options are very expensive.
Hi Pele,
Here is a manual selector valve that should work well for you. It's a 3-port and costs about $16 each.
MSC Industrial Supply Co. Home Page
Part # MSC # 73305781
Also, there is a company called Anderson Brass online (google it), and they make both 3 and 6-port manual switching solenoids. Anderson's prices are pretty expensive though.
Good luck!
Good luck!
Anderson Brass Company | Manufacturers of Miniature Ball Valves, Brass Ball Valves, Drain Valves, Specialty Valves, Check Valves, Mulit-port Valves, Hartsville, SC
That's the Anderson site. I'm pretty sure that both those valves would be able to withstand diesel. I know a guy who was using the brass MSC 3-port manual valves for running hot vegetable oil, and apparently they have been working well for years.
lawrencewatts
18
12-22-2013 12:52 PM
ToddShroats
07-15-2012 11:19 AM
Breaker Breaker 3-3
02-12-2012 10:45 PM
maschronic
07-19-2011 07:58 PM
