Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-03-2008, 02:10 PM
'86_150 is starting off with a positive reputation.
vacuum lines and code
on my 1990 f150 with the 5.0 i just replaced the head gaskets and i was positive i marked all of the vac lines but i guess i missed one so i know the long vacuum line on the pass side goes to the egr but where does the shorter line that comes out of the harness on the front of the engine go? and i pulled this code i forgot the number but the book said it was the fuel pump secondary circuit failure what does this mean? any help is appreciated thanks much.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-08-2008, 08:55 PM
EPNCSU2006's Avatar
EPNCSU2006 has a good reputation on FTE.EPNCSU2006 has a good reputation on FTE.
Do you have any pictures of the vacuum line and its location? I would reset the fuel pump code (just pull the jumper wire while the codes are blinking) and see if it comes back. If it does and the fuel pumps still work, I'd just ignore it.
__________________
Eric
'87 F150 302 manual 4sp overdrive 4x2
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
